Old 12-02-2006, 09:11 AM   #1
2007 25' Safari FB SE
Lake Forest , Illinois
What Is All This Caulking?
I have a new 2007 25' Safari. I decided to wash it and when I crawled up a ladder to wash the AS, I noticed that many of the seams around the top of the windows and also on the roof were caulked with a silicone material. When this material ultimately wears off will the seams start to leak or is this going to be a maintenance issue. Maybe its there for only preventative reasons. My first thought was that the AS had been factory tested and the caulking was placed around the seams to correct leaking problems.
woodedareas is offline   Reply With Quote
Old 12-02-2006, 09:31 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Oh, the young guys at the factory are pretty wild with their caulking guns. There is no attempt to be pretty when it is out of sight on the roof. It seems to be what passes for normal and doesn't indicate any specific problem.
BTW -- it is most likely a butyl caulk. Silicone caulk does not adhere to aluminum and is not recommended near an Airstream!
5 meter Langford Nahanni
Old 12-02-2006, 09:42 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
They are all like that on the roof. Some a bit nicer than others, but none as pretty as the below the roofline caulkings....
Old 12-02-2006, 09:58 AM   #4
claybags's Avatar
rio rico , Arizona
If a little is good......a lot MUST be better!!!!
I haven't seen an RV roof yet that doesn't look like that. Just think of the savings if it were done properly.
Cheers, Jeff
2007 Safari 25 FB SE LS
2006 Chev Express 3500 Duramax
Predator tuner
Equal-i-zer hitch
"Home is where the ART is"
claybags is offline   Reply With Quote
Old 12-02-2006, 10:10 AM   #5
codybear's Avatar
1964 22' Safari
SACRAMENTO , California
Images: 315
tempro
Hi,
Just ordered online a couple of tubes of Tempro (formerly vulkrem (sp) at the Vintage Trailer Supply..I also ordered a couple of the disposable syringes for only .75 cents each..I thought maybe I would be able to get a fine bead where needed..any suggestions as to applications on leaks?..do I want to be liberal-handed or use a fine-bead w/this stuff?..I think when my in-laws owned it, my father-in-law spread it all over!!
codybear is offline   Reply With Quote
Old 12-02-2006, 10:42 AM   #6
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Dear Woodedareas-
As Conoe mentions it is butyl caulk. And as mentioned in the case of caulking any RV roof, more is better. As I sit here in my comand center at home on the second floor I have a direct view of my AS roof. I see a spot or two that could probably use more gunk! Plus, I think the boys at JC get paid not by the hours they work but by the amount of goop they use!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-02-2006, 02:22 PM   #7
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
I had some "blobs" of white caulking out in the middle of the roof....no seam...no hole....just there. I carefully removed them.
But then found out that the "blobs" on top of screw heads above the windows were important. I inadvertently removed a couple of those "blobs" and the windows leaked on the inside..had to replace the blobs on the screws
Why did I think my Airstream was going to be different than an SOB?
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 01-23-2007, 10:35 PM   #8
Receiver of the Honey Do.
1964 26' Overlander
Pensacola , Florida
Silicon does not adhere?
So what is all the gray stuff around the vent pipes on my airstream, it feels like Silicon.. looks like old Silicon....
Hummmm.....
Dh
Dear Hubby is offline   Reply With Quote
Old 01-24-2007, 12:00 AM   #9
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
What indeed?
It is probably Vulkem or parbond or sikaflex221 sealant. That is all the factory uses on Airstreams. It is butyl and adheres to aluminum much better than silicone. Also if you ever need to remove it you will find it comes off the aluminum much easier than silicone does. Anything that save you all that scraping and cussing can't be bad...right? Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 01-24-2007, 12:06 AM   #10
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
There is another possibility...
It could be that a PO put gray aluminum gutter caulk on that area. If so it might just be silicone. If that is so....GET IT OFF!!! Replace it with some new sikaflex221. Now.... That's the ticket! It will last longer and stay softer and seal longer/better than any silicone product on aluminum...period! Nuff said! Ed
Old 01-24-2007, 06:18 AM   #11
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
How about snaping a few pics!
M
ArtStream is offline   Reply With Quote
Old 01-24-2007, 07:28 AM   #12
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Abit off topic but:
I was somewhat amazed getting into the innards of my 71 of the sloppy work the factory left behind where it couldn't be seen. Missing rivets, screws, sloppy floor and sheet metal cuts, construction scraps just left there, etc.
Old 01-24-2007, 04:46 PM   #13
M
My Airstream is out in Arizona and I am in Illinois, but will get some pics when I get out there.
Old 01-24-2007, 05:33 PM   #14
WALLY 54's Avatar
1954 25' Cruiser
1977 27' Overlander
1990 34.5' Airstream 345
VC Highlands , Nevada
Vulkem rocks
I think they are using Sikaflex now. But they used to use Vulkem for the larger cracks and Parabond for the thin, tight seams.
Our 77 Overlander 'Buttercup' has thick beads of gray mushy caulk at the top of the windows and door. I was told that back then they did use the gray plumbers putty as a sealant. It is still soft in areas. I removed some of it where I couldn't save it.
Somewhere along the line someone went over all of these areas, and all of the vents and a/c on the roof, with white plastic caulk and milky-clear silicone caulk. What a mess.
Got rid of that stuff by peeling, scraping then wire brushing.
Then I re-sealed everything with Vulkem. (took notes and studied Daisy's posts and web site). Even the tiniest slits. Once I got the hang of it it went very quickly. Not a leak since!!!!
I do see some cracking in areas lower to the ground -- around the trim and wheel wells. We do live in a very dry climate and this year has been especially cold and dry.
k
VAC 1 V.P. & Vintage Advantage Magazine Editor
WALLY54 1954 Cruiser #11281
Buttercup 77 Overlander #17330
1990 345-LE MoHo Classic #7830
Air #
19124
WALLY 54 is offline   Reply With Quote
Caulking underneath? Kistler Our Community 2 07-10-2003 07:25 AM
Caulking Kistler Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-19-2003 12:32 PM
Sealing Windows & Caulking outside mgordon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-13-2003 12:18 PM
Furnace Exhause Plate Caulking niftypkg Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-23-2002 07:32 PM
caulking ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-10-2002 02:13 AM
