Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 05-26-2008, 01:56 PM   #1
Zstream
MyFirstStreamer
Zstream's Avatar
Profile:  1963 26' Overlander
Indiana , Indiana
Question What caulk goes here?
Next up- Sealing top strip above window frame and where the external skin panels connect... What caulk do you all use to seal these areas? I have attached 2 pictures of the area in question:
#1 See the tip of the tool? What caulk is good to use in that "channel"?
#2 See the rivets where the panels meet? Is it possible to work-in a tiny bead of caulk in the tiny gap between panels?
Tks, Z.
A chief event of life is the day in which we have encountered a mind that startled us. -Emerson
Burning Man ~ Black Rock Desert Nevada 2005 & 2006 -Zstream
Zstream is offline   Reply With Quote
Old 05-26-2008, 02:19 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
You should use Vulkem, or Silkaflex. Vulkem for the larger gaps, and Silkaflex for the smaller ones. You should never use caulk on an Airstream, some of the materials found in it will attack the skin of the trailer.
Change is inevitable, except from a vending machine
AIR#2611
Old 05-26-2008, 02:35 PM   #3
Zstream
MyFirstStreamer
Zstream's Avatar
Indiana , Indiana
Hey Thanks. Where do you buy Silkaflex? What color is it? I have lots of Vulkem. I used it to seal the new roof vents. But somehow did not think it the right seal for exterior gaps and around the window frame...& yes I was using the word caulk incorrectly... I should have said seal product etc... Tks, Z.
Old 05-26-2008, 02:37 PM   #4
overlander63
Images: 58
I got a tube from our local Airstream dealer, plus it's available from the Airstream store, Inland RV, and I seem to remember seeing it at Vintage Trailer Supply.
AIR#2611
Old 05-26-2008, 03:32 PM   #5
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
The Sikaflex you want is Sikaflex 221. The gray color is a close match for aluminum. Here's a link for the gray - Austin Hardware & Supply Inc. :: Sealants & Adhesives :: SIKAFLEX 221 :: 221-G
You'll probably want to find a finer application tool. I'm thinking maybe a syringe without needle from the vet area at a local farm & fleet store.
Old 05-26-2008, 03:40 PM   #6
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Sikaflex is good stuff as is the Trempro 635 which I have used over the last couple of years. Both are available at Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Just checked and the website shows Trempro 635 and Vulkem 636 which is a little slower to set up than the 635. Interesting that Tremco is in the process of deleting the name Vulkem from their products. I didn't see the Sikaflex.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Caulk around furnace vent housebg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-10-2006 01:13 PM
Caulk, what's some equivalent? lundfog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 06-18-2006 07:57 AM
caulk removal cherring Parts Archive 3 09-14-2003 06:45 PM
Caulk source? wyhjr Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 03-08-2003 04:14 PM
caulk removal Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 10-17-2002 08:56 AM
