Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 08-23-2006, 11:25 AM   #1
jim.bailey@e
Profile:  1972 31' Sovereign
Rocky Mount , Virginia
Unhappy wet floor at door
I have a 1972 31' Airstream, rear bath. Water is seeping up from the sub floor just in front of the entry door. It is not a lot of water; over a recent 12 day stay, the wet place on the floor increased from a 6" spot in the middle of the door entry way to a wet spot about 24" by 24" in the doorway entry. I checked: the supply pipes for the kitchen sink, the drains and the Dometic two door ref.. I can find NO SOURCE for the water!! Can anone help?
jim.bailey@e is offline   Reply With Quote
Old 08-23-2006, 11:35 AM   #2
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
How much rainy weather did you have over this period? Was your awning deployed? If so, it might have come between the skins from a distance up on top. Maybe A/C sealing, maybe a roof vent that is not well sealed.
Again, what was the rain situation?
Old 08-23-2006, 12:35 PM   #3
jim.bailey@e
We have had a record drought year; no rain since early June!!
I think the water is coming from a Airstream system source, but I can't find it.
Thanks for your thoughts.
Old 08-23-2006, 01:41 PM   #4
CanoeStream
Images: 13
Virginia, eh? What appliances are close by? Fridge? 30 amp campground power probably allowed you to run your A/C. Right? It could be condensation from either of those sources not going the right direction. The A/C drain might be plugged -- and it really could end up this far from the source!
Let's see what other readers might say as Forums activity heats up later this afternoon and evening.
Old 08-23-2006, 02:32 PM   #5
jim.bailey@e
I checked the Fridge for defrost water & this is not the source. The A/c was not on at all during the 12 days (W Va. Pan handle mountains no need).
thanks
Old 08-23-2006, 08:38 PM   #6
SafeHarbor
Round on both ends
SafeHarbor's Avatar
Profile:  1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Well, in the old no-fun thoughts, that might leave... tanks, water heater, and shower plumbing. If you deliberately raise the nose, does it go away? Okay, that might take several days to determine.
And this is assuming that it really is seeping UP.
Anyway, the bellies are not designed to be water tight. I'd think anything soaking the underfloor insulation would rather leak OUT than leak UP. Have you scooted around under the trailer looking?
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-23-2006, 08:46 PM   #7
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Sink traps?
Is your galley on that side of the trailer? My trailer is newer, but I have had a lot of trouble with the joints on the traps under the sink coming loose. Our first clue was finding some water in a pan that was stored under the sink.
I believe the trap joints become loose from temperature changes. I tighten them as tight as my arthritic hands allow and they will be loose again a couple of trips later.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 08-23-2006, 09:12 PM   #8
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
Turn off the city water supply and turn on the water pump. Does the pump intermittently cycle?
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 08-23-2006, 10:12 PM   #9
GT1963
LADYBUG
GT1963's Avatar
Profile:  1963 19' Globetrotter
2005 22' International CCD
Lakefield , ON
Images: 59
I think it might be either your pump or a small leak in one of your pipes. If you are not perfectly level side to side a small trickle can easily "wrap" around the front inner skin and settle at the door.
You have had no rain so that eliminates any outside leaking.
The AC is a good one but if you are not running that then that is eliminated.
Fridge is out - check all the water heater connections including your pressure valve.
Check all the on/off valves and the old city water regulator for slow leaks.
Last would be your fresh water tank - if up front that could be a good source for a leak.
That is all I can think of....Good luck.
Streaming in the spirit of Exploration...
"To go places and do things that have never
been done before-that's what living is all about."
- M. Collins
Peter & Sharon
WBCCI #1963 & 1961
GT1963 is offline   Reply With Quote
Old 08-24-2006, 01:23 PM   #10
jim.bailey@e
Thanks to all for several good ideas for me to check. We will be staying in it over Labor day & after. I will report if problem is solved.
Jim & Betty
Old 08-28-2006, 02:51 PM   #11
jim.bailey@e
I am going to my A/S Labor day. Thanks for the wet floor ideas. Any new ones?
Old 08-28-2006, 03:49 PM   #12
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
jim
i think all the ideas suggested are good ones, if i remember correctly your kitchen and water pump are next to the door on the left as you enter.
i would start there if you have had no rain. otherwise, the door gasket would be number one on my list!
john
you call them ferrets, i call them weasels.
Old 09-06-2006, 10:57 AM   #13
jim.bailey@e
Thanks to all for help. Betty found the leak in a drain joint at the wheel well. It was leaking at the back of the joint & dropping on to the seam of the wheel well & NOT on to the shelf. The seam carried the water to the underfloor & it seeped out at floor at the door. She fixed it with epoxey putty for plastic. Very easy fix!! Esp. since I didn't have to do it!
Best Wishes
Jim & Betty
Old 09-06-2006, 02:06 PM   #14
steelbird312
steelbird312's Avatar
Profile:  1989 29' Excella
Griffin , Georgia
Images: 11
Jim,
Although Betty had the very best of intentions, I would not trust the repair as far as I could throw it. The movement that items experience while you are driving (towing) and the fact that epoxies, glue, etc just has a bad habit of not adhering well or permanently to water pipes, both metal or plastic would cause me to take a couple of hours and $5 spent at Home Depot and fix it right. It is so much easier than chasing it down two or three times, or even worse, thinking it is fixed and rotting a hole in the subfloor, only to find it later.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Door Catches niftypkg Doors & Locks 4 05-22-2007 06:09 PM
Looking for Refer. Door Shelf InsideOut Parts Archive 23 06-17-2004 07:08 PM
Main Door buckmaster 1965 Globetrotter 0 10-19-2002 08:47 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 06:53 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 09:31 AM
