Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 09-06-2006, 03:23 PM   #15
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Originally Posted by jim.bailey@e
I have a 1972 31' Airstream, rear bath. Water is seeping up from the sub floor just in front of the entry door. It is not a lot of water; over a recent 12 day stay, the wet place on the floor increased from a 6" spot in the middle of the door entry way to a wet spot about 24" by 24" in the doorway entry. I checked: the supply pipes for the kitchen sink, the drains and the Dometic two door ref.. I can find NO SOURCE for the water!! Can anone help?
Check the entrance door gasket for a tight fit.
You can close the door on a dollar bill. Slide the dollar bill around the entire door gasket. If it moves easily in any particular area, you have a water leak there when it rains.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Door Catches niftypkg Doors & Locks 4 05-22-2007 06:09 PM
Looking for Refer. Door Shelf InsideOut Parts Archive 23 06-17-2004 07:08 PM
Main Door buckmaster 1965 Globetrotter 0 10-19-2002 08:47 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 06:53 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 09:31 AM
