Old 12-03-2014, 03:18 PM   #1
Anchorage , Alaska
Weather Stripping the Battery Box
Not sure if this question is better posted in the electrical forum. I am restoring a 1963 Bambi. About done closing leaks in the exterior skin. but noticed the floor was damp due to leaks from the battery box. I have read several cautions that the battery box should not be sealed due the potential of gases put off by the battery.
As I recall, this area was one of the most rotten areas in the floor. I thought it was due to potentially corrosive leaks from the batteries over time. But I'll bet a good part was also due to exterior water leaks. Attached are some pics of a battery box opening from a sister Airstream of similar vintage.
I could caulk around the base of the box, and weather strip the inside edges of the opening, but not sure if this would be wise. What would be safe and appropriate to keep the water out, yet properly ventilate this area ?
ID:	227963   Click image for larger version
Aktundra is offline   Reply With Quote
Old 12-03-2014, 03:53 PM   #2
Images: 59
As long as you keep the two holes in the door open it would be OK. You need one vent high and one vent low.
Old 12-03-2014, 06:00 PM   #3
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
You might consider eliminating the whole problem by sealing up the outside door permenately and going to AGM batteries that don't need outside venting.
Advantages: 1) no leaks, 2) they last longer, 3) zero maintenance.
Disadvantages: 1) cost more (made up by longer life).
Silver Hawk is offline   Reply With Quote
Old 12-03-2014, 07:20 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Actually, one hole high in the door is all you need, and one hole in the floor that serves as both an inlet for air and an outlet for water. And elevate the battery slightly (about the height of a Lego block) so that water isn't trapped by the battery.
Also, shape the vent hole so that water is deflected away from the hole instead of dripping in. Easily accomplished by inserting a wooden dowel into the vent hole that is about the same diameter as the vent hole, then pressing down gently. This will slightly bend the top edge of the vent hole outwards, and the bottom edge of the vent hole inwards. This will help prevent water dripping down the door from getting in, though it won't provide perfect protection against wind-blown rain.
By the way, even battery boxes for AGM batteries are required to be vented. AGMs don't spill, but they can outgas. They don't outgas as much as a wet-cell, but they do outgas. Which is why you can use an AGM in any position except upside down (if upside down, lighter-than-air hydrogen gas can't escape).
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
Two ?'s Furnace and weather stripping escapeez Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-15-2002 06:10 PM
Need new weather stripping kit lizh Windows & Screens 8 08-30-2002 07:49 PM
Window Screen Weather Stripping ??? niftypkg Windows & Screens 0 06-03-2002 06:28 PM
