Old 01-23-2012, 10:54 AM   #1
2004 16' International CCD
Orem , Utah
Weather stripping for 2004 bambi
The rear glass has an obvious leak on right side gasket is pushed to left. Sure I could reglue old one on but hey new makes more sense. Rear cargo area gasket is torn right cable slit through and left side rivet is broke. Door I can see some day light may as well toss on new. Where can I order the correct parts. Also looking into adding diamond plating in rear storage area instead vinyl wool look. I should diamond plate the whole inside of rig. Anyone done this how did you cut diamond plate
starcraft is offline   Reply With Quote
Mysterious Electronics - 2007 19' Bambi randf Electrical - Systems, Generators, Batteries & Solar 15 05-31-2012 05:11 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Screen Door Weather Strip TBRich Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 12-17-2011 04:00 PM
1961 BAMBI :: 1961 Airstream BAMBI SILVERSAILOR Airstream Registry Discussions 0 08-19-2011 08:31 AM
Window weather stripping size / dimensions? AirHome Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 03-14-2011 09:58 PM
