Old 02-17-2007, 12:20 PM   #1
argosy75's Avatar
1975 Argosy 24
Graham , Washington
Images: 32
waterleak on floor
I have a 1975 Argosy. I was pulling up carpet to install bamboo laminate flooring in my trailer and noticed water stains on the wood flooring 2 to 3 ft. on either side of my door and also in the dinette area. After searching I'm sure there are more water spots throughout trailer! I'm in the process of replacing over 8 ft. of plywood where dinette goes and by front door. The water is only at base of wall at floor level. Trailer is covered with tarp 1/3 of the way all around. I haven't put new subfloor down yet. I've caulked all rivets, trim, awning brackets, tightened bolts on awning and when it rains just a little bit, I see water dripping on the inside of wall sheating onto skin covering under trailer. Do I have put new rivets in trim? Does anyone have ideas about sealing trim to stop water from getting in my trailer onto floor? I'm desperate. Any suggestions would be greatly appreciated.
argosy75 is offline   Reply With Quote
Old 02-17-2007, 12:48 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Welcome to not-very-exclusive club...
Sigh...
Sorry to hear of water leaks, but you're sooo not alone... There is only one "General Theory of Water-Leakivity" and it states that water will try to go from wet to dry and will always obey the greater laws of gravity and momentum...
You should really try searching and reading threads with key words like water + leak(s) + seal etc... There are a number of stories with some pictures and detailed advice on stopping water leaks...
That said, the process is generally along these lines:
1. Find out where the water is getting in.. (Hoses, smoke, pressure testing are all useful options..) Leak has to be somewhere above and with path downwards to where water is discovered... May be more than one source.. Roof vents, Air Conditioner gaskets, running lights and TV antennas are often good alternate entry points...
2. Use proper sealant to make it stay out (NO Silicone, but potentially lots of Vulkem or Sikaflex or other poly sealants)
3. It may require rubber parts like door or window seals also
4. Then fix damaged areas of wood, etc
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-17-2007, 02:41 PM   #3
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hello.. Yes, do put parbon or silkaflex above the beltline and especially above the rub rail.. also another place is the tv antenna.. have removed them from the past 2 Argosys we have had...
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 02-18-2007, 08:03 AM   #4
argosy75's Avatar
1975 Argosy 24
Graham , Washington
Images: 32
Thank you. I will show these replies to my husband and get back to you.
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 06:28 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
Total floor replace 74Argosy24MH Repairing/Replacing Floor &/or Frame 1 06-27-2002 04:05 PM
