Old 10-18-2002, 03:32 AM   #1
Question water seeping in compartment door
The rear compartment door housing my battery etc does not shut entirely tight and there is water seeping in (lots of it) through that opening. I need to replace the stripping around the door but I still don't think that will work. Suggestions? 'Thanks.
Mike is offline   Reply With Quote
Old 10-18-2002, 12:12 PM   #2
The gasket is the key, assuming the door is not damaged.
inlandrv.com
airstreamparts.com
Old 10-19-2002, 07:32 AM   #3
Hi and thanks for your help. The door does not fit tightly against the frame, there is some space where the water can get inside. would replacing the gasket prevent seepage even with a gap?
Old 10-19-2002, 06:28 PM   #4
New Borockton , Alabama
Images: 21
It sounds like the arm of the lock that rotates and holds the door in place when locked is bent inward and not allowing the door to close flush with the trailer. I had that problem with my battery compartment doors and bent them back into place with no problem afterward. If you can push on the door and make it flush then I would try that first.
Randy
Old 10-23-2002, 12:14 PM   #5
thanks Randy, I was thinking of trying that also. I guess they should have put a lip over that door, would have saved me alot of headaches!
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 01:30 PM
Need spring load clips for water heater door 68 GT. Jim Clark Water Heaters, Filters & Pumps 4 05-09-2002 07:39 AM
