Old 08-31-2002, 10:01 PM   #1
Rob
Water proofing
Ok I m going 100 diffeent directions at once with this project. I started by replacing the wheels ,tires and axles. Safety 1st
Now I want to make the trailer water tight. One place I noticed water damage was at the rear where the skin meets the trunk area (the trunk or storage area between the bumper and trailer is missing on mine). If I look closely I can see the plywood flooring from the rear of the trailer.
Has anyone delt with this problem? Maybe if I purchase a trunk lid it will come with some sort of seal between the skin and lid.
I hate the thought of spreading a ton of sealant in the area.
Rob is offline   Reply With Quote
Old 08-31-2002, 10:37 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Others will pipe in and tell you how to do it, but I have been told that this is a spot that can be difficult to keep sealed. My understanding is that you will need to run a bead of sealant in there, the trunk lid does little in the way of sealing the exposed wood. I do not know what sealant to use, but I know not to reccomend silicone.
Good luck on your re-do!
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 01:12 PM
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 12:50 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 01:03 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 11:28 AM
