Old 08-28-2012, 08:24 PM   #1
TankerIP's Avatar
2002 22' International
Water lnlet Pipe Leak - Fixed
Here's something for you all to keep an eye on. I first noted the possibility of a leak when I saw water dripping from the banana wrap to the ground toward the rear of the trailer. At first I suspected and worried about a bath vent pipe leak where after a rain the leak would track down within the walls to the floor area.
After inspection I saw the insulation soaked where the water supply comes in the trailer. The connector fitting on the inside has 4 screws that attaches it to the external water connector. It is a pressure reducer. Just by taking a phillips screwdriver and tightening the screws I was able to stop the leak! I wonder if on the road vibration caused this to loosen?
I hope this leak has not gone on for too long. Obviously, the water soaked the floor within the c-channel before exiting outside to drip on the ground. I have a fan blowing in there now to dry as much as I can and just hope that I won't get too much rot.
I will now have to keep a regular eye on this in the future, and may have to replace the internal fittings.
TankerIP is offline   Reply With Quote
