Old 08-02-2011, 11:29 PM   #1
Hardworking's Avatar
1964 19' Globetrotter
Duluth , Minnesota
Water leaks
Hello
I have a little problem, and not sure how to fix it. Two of my windows leak. Front one in the lower corner. One of the side windows .... Get this ... Leaks not in the corner but half way down the side. I think I need to get new window gaskets ( the little rubber strip) not real sure. And leaking from the two back pipe vents in the roof. Any help would be great.
Sara
Hardworking is offline   Reply With Quote
Old 08-03-2011, 07:38 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard....
Sara,
Lots of help here.
Only one requirement.....you MUST post Photos!!!
Inland RV Center - The Nations Leading Expert in Airstream Innovations
Vintage Trailer Supply - parts and supplies for vintage travel trailers!
Two of the BEST places to start your project!!!
Good Luck
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 08-05-2011, 09:02 PM   #3
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Hi Sara!
Lots of leaks in older AS is what I see as the 'norm'. I have learned from some great minds w/ lots of experience on this site that leaks rarely come from were you think they originate. Keep posting, with as much detail as possible.
captmatt is offline   Reply With Quote
Old 08-05-2011, 09:59 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
My trailer had some leaks. My strategy was to do all the maintenance and not try to locate and eliminate every individual leak. I started at the top, and worked my way down to the step release slot.
At the top, I replaced all the clearance lights with new gaskets and butyl putty. I replaced the sewer vent seal gaskets and sealed the cap screws with Vulkem 116 gray. I replaced the air conditioner, removed the television antenna, replaced the roof vents with Fantastic fans, sealed seams, sealed the awning channel, found and fixed 5 missing rivets under the awning roller, replaced all the window and door gaskets, and sealed lowed body seams and rub rail rivets.
I now have a dry trailer. We just had a 5 inch in two hour rain and totally dry.
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 08:02 PM
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 10:52 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 04:11 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 06:42 PM
