Old 04-08-2011, 09:54 PM   #1
2004 25' International CCD
Brookfield , Wisconsin
Water Leak bumper Airstream
I've read many posts on bumper leaks. Most of you suggest that it is a bumper/panel leak. Airstream manufacture tells me it's an easy fix, dealer tells me best case scenario it's a $500 fix...
I dropped the bottom rear pan removed the insulation had mold on it. Had to discard mattress it had strong foul smell.
Looking for some advice, is it a do it yourself project or once you get into becomes a nightmare fix.
How can you be sure it is a bumper/panel leak? I don't see how water can find its way into Airstream everything looks pretty tight from the outside. S
Service suggest running water hose where water leak is suspected.
See pics.
dany
Name:	From internet search.jpg
ID:	126466   Click image for larger version
ID:	126468   Click image for larger version
danyfr67 is offline   Reply With Quote
Old 04-08-2011, 09:57 PM   #2
Airstream bumper water leak
Picture of removed rail and insert is not from my Airstream it is from a previous post.
Old 04-08-2011, 11:57 PM   #3
2005 22' International CCD
Aliso Viejo , California
I had leaks in that exact area which I thought was the bumper. It turned out to be the rear fantastic fan. Easy fix for me.
Davern1 is offline   Reply With Quote
Old 04-09-2011, 12:22 AM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, trying to be on the safe side, I sealed the bottom of the moulding, resealed the top of the moulding, and sealed off both ends where they meat the frame. This way water can't get in there and I didn't have to remove the body moulding to do it. I do not know of any leaks or damage in this area, but sealed it anyway. Seems to me that the trailers with the rear storage door [front too on some models] and those with the wrap around windows are most prone to leaking.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-09-2011, 10:28 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
These rear bumper area leaks are just to common, with fans, windows, body moulding all suspect. Here's another thought. If you seal the body moulding top and bottom, can water enter through the rivets that hold the body moulding on? The rivets are covered by the moulding insert, but I don't think that stickum holding the insert is keeping water out. That is why I am hesitant to seal the bottom of the moulding, so it can drain.
Doug
Old 04-09-2011, 10:41 PM   #6
Salem , Oregon
Images: 18
Hi, the mouldings stick really good and I don't think any water can get in there unless you have a loose moulding; Mine are really tight. Time will tell.
2005 Safari 25-B
Old 04-10-2011, 12:47 AM   #7
idmtman's Avatar
Worley , Idaho
I just sealed the bumper area on my 28' Safari. I went ahead and removed the rub rail and laid down a nice bead of TremPro, screwed the rub rail back on and caulked the top of the rub rail with ParBond. I am waiting for warmer weather before putting the chrome trim back on with 3M double-sided tape. So far, this appears to have solved the problem.
See this thread: http://www.airforums.com/forums/f456...ybe-56674.html.
IMHO, if you have a leak, it is worthwhile removing the rub rail to insure that no water can penetrate from the top of the bumper under the rub rail. I did not seal the bottom of the rub rail because I want any water that might get under the rail to have a way to drain out.
Idmtman
2006 Safari 28' SE (Sylvia)
75th Anniversary Edition
2010 Toyota Tundra 4x4
TAC: ID-1
idmtman is offline   Reply With Quote
Old 04-10-2011, 08:35 AM   #8
The caulk on the trim (rail) looks really tight. I just don't understand how water can seep in. I applied water on the trim/insert yesterday and confirmed that water was leaking through. I just can't see any gap. Dealer wants $500 to fix the leak. Is it an easy DIY project? Can I resuse the screws that are holding the trim, can I reuse the holes to screw back the trim? I know i will need to buy a new insert.
I also need a new mattress any tip on that?
Old 04-10-2011, 09:00 AM   #9
idmtman's Avatar
Worley , Idaho
The water appears to seep in under the rub rail from the standing water on the top of the bumper. My rub rail was screwed in (partially) due to the fact that this "fix" had been done before (but not well). Yours may be have rivets. Either way, the job is not as bad as it sounds. You can drill out the rivets with a 1/8" drill bit. Since the rub rail is two pieces butted together at the rear of the trailer, carefully remove the chrome trim (all of it), and then starting at the rear of the trailer, remove the rivets or screws until you can pull the rub rail back from the bumper. You will not need to remove the rub rail completely. Then do the same on the other side. I took mine back around the curve and that exposed the area I needed to caulk sufficiently.
At this point, you will need to make sure everything is dry and clean. I would mask off the bumper section to make sure the caulk stays in the area under the rub rail, then lay down the caulk and tool it into a nice bead. Once the caulk cures, you can reattach the rub rail (screws or rivets), then you will need to caulk the top of the rub rail. I used Parbond which cannot be tooled but can be wiped into the gap with a rag soaked in solvent (I used Xylol, although Out-of-Doors Mart recommends body shop alcohol). They have a great video on using Parbond)
As for reattaching the chrome strip, I would say this has taken the longest because it took me 3-4 hours to completely remove the old adhesive from the back of the trim using a plastic putty knife and denatured alcohol. It would be easy to damage the trim with a metal putty knife. I went back again and tried Xylol and a fingernail to remove the last traces. Then I applies the 7/8" 3M double-sided trim tape. That is as far as I have gotten because the directions on the tape say it should be applied in temps of 65 degrees or above which we have not yet had here.
As for the mold, you can clean that off with a bleach and water solution and then replace the insulation assuming the floor is sound.
As I indicated above, this particular leak had been "fixed" before, but not very well. The caulking was not tooled so there were places where it had not adhered very well and that is where I experienced the leak.
Good luck.
Idmtman
TAC: ID-1
Old 04-14-2011, 05:14 PM   #10
Can I use goo gone to clean the remaining of the vulkem left on the rub rail and body of Airstream or mineral spirits?
Old 04-15-2011, 12:16 AM   #11
idmtman's Avatar
Worley , Idaho
If it isn't completely cured, Xylol will take it off.
Idmtman
TAC: ID-1
Old 04-15-2011, 08:44 AM   #12
dznf0g's Avatar
Oswego , Illinois
Just a suggestion for next time. I always tape off the seam/moulding to be sealed with painters tape so I get a nice uniform look and no cleanup. However, because some of the sealers (parbond, in particular) skins or sets up really fast, seal about 2 - 3', then remove that 2 - 3' feet of tape, and proceed in in that manner. Otherwise the sealer will wrinkle and pull.
Old 04-15-2011, 06:21 PM   #13
I haven't applied the Vulkem yet I am trying to remove what's left from the old seal of the body and rail
Old 04-16-2011, 01:07 AM   #14
idmtman's Avatar
Worley , Idaho
The suggestion our AS dealer made was to use blue painter's tape to protect the plastic coat on either side of the area in question and carefully scrape off the old caulk with a blunt instrument (not metal). I have had limited success with that. Denatured alcohol, kerosene or xylol will loosen the old caulk but be careful not to rub too hard.
Idmtman
TAC: ID-1
Old 06-07-2011, 08:38 PM   #15
art
leaker
I hit the girl with a hose everywhere and couldnt make it happen .Im going to dry her out and start looking again .I wonder what andy or airstream might say about this problem we are having?
art is offline   Reply With Quote
Old 06-07-2011, 08:43 PM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Mods combine these?
http://www.airforums.com/forums/f249...eak-78200.html
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Fresh water leak Stearns Fresh Water Systems 8 03-24-2011 10:52 AM
Airstream water heater door LKSD Water Heaters, Filters & Pumps 9 03-23-2011 05:46 AM
Water Leak in Plumbing eldin Fresh Water Systems 8 03-17-2011 08:43 AM
