Old 06-20-2007, 07:56 PM   #1
PoconoAir's Avatar
1965 17' Caravel
Canadensis , Pennsylvania
Images: 26
Water Coming in the Reefer Stack
We had a heavy rain last night and I see some water here and there but not surprising since I did not finish going over the skin. But I was up looking over the reefer stack cover and wonder if anyone else suspects water often does this in a downpour. It looks to me like that stack cover was designed for flat roof applications. I am considering blocking the upper side of the plastic cover and maybe making air flow on the lower side easier. I do like the shape of the plastic cover but...
Barry
Name:	Ref. Cover Water.jpg
PoconoAir is offline   Reply With Quote
Old 06-21-2007, 07:17 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Could you post a picture? I believe that the original was Aluminum but I'm not entirely sure. I do know that it is aluminum on my 71. The plastic one my not be the fight shape or sets to high. The aluminum vent on my 71 is enclosed on the top side.
Aerowood is offline   Reply With Quote
Old 06-21-2007, 07:28 AM   #3
campngirl's Avatar
1964 24' Tradewind
dousman , Wisconsin
The refer vent cover on my 64 is plastic, cracked and looks to be original????
I am curious as to what others have and any modifications or improvements that have been made.
Karol
campngirl is offline   Reply With Quote
Old 06-21-2007, 08:37 AM   #4
PoconoAir's Avatar
1965 17' Caravel
Images: 26
Does anyone have a 'feel for" how freely air should be able to exit this vent? If some on later models are just open on the bottom (coming from the factory) that is good enough indication for me.
Here is a pic and the upper side looks exactly like this.
Barry
Old 06-21-2007, 08:44 AM   #5
Karol
Metal reefer vent covers have been available for replacement of the old plastic covers, for over 37 years.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-21-2007, 08:45 AM   #6
Barry
Air comes in thru the bottom of the floor, behind the reefer, then exhausts thru the exterior vent cover.
Your cover is plastic. Metal replacements are available.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-21-2007, 08:53 AM   #7
campngirl's Avatar
1964 24' Tradewind
dousman , Wisconsin
Barry,
The refer vent cover on my 64' looks exactly the same as yours. I am going to replace it w/ metal. Have a patch on the the vent cover and haven't experienced any water comming down..... although that had cross my mind.
I was going to suggest that you ask Andy/ Inland RV and specifics, but I see he already got back to you.
Karol
Old 06-21-2007, 08:54 AM   #8
campngirl's Avatar
1964 24' Tradewind
dousman , Wisconsin
Thanks Andy,
I will be replacing old vent cover w/ a metal version.
Karol
Old 06-21-2007, 11:57 AM   #9
PoconoAir's Avatar
1965 17' Caravel
Images: 26
Is the metal replacement part open on the top? I see your picture here:
http://www.inlandrv.com/parts/84000-refrventcvr.jpg
but can not tell if the bouncing rain is controlled or not. Replacing the OE plastic one with metal is a no brainer.
Old 06-21-2007, 12:23 PM   #10
PoconoAir's Avatar
1965 17' Caravel
Images: 26
If they had made a better tool and used deep draw aluminum killed steel the part would not have those rinkles along the edges. I will probably fabricate mine out of fibreglass reenfotced polyester and redesign it at the same time. I do like the shape of the OE part though so I will try to retain that look. The FRP reefer chimney went pretty fast since no changes had to be made.
Andy can you give us the background/history on the metal replacement part?
thanks
Barry
Old 06-21-2007, 12:28 PM   #11
PoconoAir's Avatar
1965 17' Caravel
Images: 26
Deep drawing
Oh, make that deep draw aluminum!!! Sorry
Old 06-21-2007, 12:34 PM   #12
thanks
Barry
That part is made by the Airstream factory.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-21-2007, 07:19 PM   #13
PoconoAir's Avatar
1965 17' Caravel
Images: 26
Mine is a little bit faded but looks like it was some sort of marbalized coloring. It definitely was not designed for this application because the bottom surface is FLAT! It has such a nice shape I have to either reproduce it in FRP or reinforce it with "fibreglass" on the inside and make the corrections. If one were to close off the top it probably should be slid down the roof an inch or two. No one seems to know if the metal replacement part is open or closed on the top. Maybe I can find a better picture on the net somewhere.
Old 06-22-2007, 09:24 AM   #14
This is a photo of the Airstream reefer vent cover that has been used for over 35 years.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-22-2007, 11:44 AM   #15
PoconoAir's Avatar
1965 17' Caravel
Images: 26
It was probably Penn State where the famous exchange took place between two Ag. students. One asked the other "Why are the rows of corn so far apart?" and the classmate answered something like this: "That was the closest the rows can be and still get a horse between the rows and it has been that way ever since." Gotta go redesign.
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
