Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 08-28-2002, 01:40 PM   #1
gwsullivan
gwsullivan's Avatar
Profile:
Vulkum or Silicone??
I have found several threads addressing the installation of Fantastic fans but I can not find any information on the type of sealer they used. Vulkum, Silicone or some other product?
Thanks in advance for any information.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 08-28-2002, 02:56 PM   #2
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Sealer
Jerry,
The sealer to use is: SIKAFLEX, Part #360180 from the A/S factory, cost is $8.15
Good luck
Vern
AIR 807
53flyingcloud is online now   Reply With Quote
Old 08-28-2002, 06:19 PM   #3
Kirby Stone
Profile:
Vulkem or Silacone
I have used Vulkhem for many years on my Airstream, and around the house.
It lasts extremely well, it sticks better than any silacone I have ever used.
A trick is to use a dishwashing soap and water mixture to
smooth the surface with your finger, it also causes the caulk
to "skin over quicker".
Also, once opened the tube will cure in a few weeks. To prevent this, put it in a sealed kitchen bag (I double bag mine) and then store it in a freezer, it will last for years this way. Just thaw it by
letting it sit out overnight in the sealed bag.
K L Stone
Kirby Stone is offline   Reply With Quote
Old 08-28-2002, 06:59 PM   #4
53flyingcloud
REPLIED TO QUESTION
"I have found several threads addressing the installation of Fantastic fans but I can not find any information on the type of sealer they used. Vulkum, Silicone or some other product?
Thanks in advance for any information."
Your 'original question' adressed the seal used in the installation of 'Fantastic Fan'. Since I had just had two Fantastic Fans installed at the A/S Factory, I wanted to share with you the "correct" sealer info you requested.
It appears to have been a waste of time.
AIR 807
Old 08-28-2002, 09:08 PM   #5
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
gwsullivan:
Never use Silicon based products on aluminum. It will turn a real nasty grey and eventually fall off, if you are lucky.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 08-28-2002, 11:03 PM   #6
DIMMER
Vagabond
DIMMER's Avatar
Profile:  1973 31' Sovereign
Semi, Pro Rock Crawler , Motorsports Photographer
SikaFlex for gaps and fittings?????????? Help me out need more intell on the SikaFlex!!!!!!!
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
DIMMER is offline   Reply With Quote
Old 08-29-2002, 09:23 AM   #7
Charcigar
Charcigar's Avatar
Profile:  1967 22' Safari
Coquitlam , Beautiful BC
I used Sikaflex for areas on my trailer above my windows....i.e. rooftop vents;pipe vents etc.It's a lot thicker and stickier to use than Vulkem but I have been told it holds up for ages.I would not use it for skin panel seams or tiny areas.....Vulkem or Parbond worked much better for me in those applications....but I recommend Sikaflex for bigger gaps that need caulking,especially on your roof.
Charcigar is offline   Reply With Quote
Old 08-29-2002, 02:09 PM   #8
DIMMER
Vagabond
DIMMER's Avatar
Ok, but where do i find some!!!!!!!!
Old 08-29-2002, 03:52 PM   #9
Charcigar
Charcigar's Avatar
The product is called "Sikaflex 227".It comes in a few colors.....clearly the "aluminum grey" being the one for us Airstreamers to use.
I purchased mine from:
http://www.cascadeaqua.com/index.html
I am in Canada,and this is a Canadian company.For a US supplier,I would do a search or go to :
www.sika.com
Should be able to locate some near you.
Old 08-29-2002, 03:58 PM   #10
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
The second post (by Towner7) in this thread states that it's available from the Airstream Factory...thanks Vern ~
Shari
Old 08-29-2002, 05:25 PM   #11
53flyingcloud
Smile Ref
Shari,
You're very welcome...
AIR 807
Old 08-29-2002, 11:51 PM   #12
DIMMER
Vagabond
DIMMER's Avatar
DAAAAAAAAAA!!!!!!!!!!! I read all the posts, But was asking if any one had found it some wear other then" Airstream"
Old 08-30-2002, 12:46 AM   #13
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
Sorry DaPlumber ~ I certainly didn't mean to offend you...I just thought you might have overlooked the earlier post...
Shari
Old 08-30-2002, 01:00 AM   #14
DIMMER
Vagabond
DIMMER's Avatar
Talking
"InsideOut" Its a Airstream thing!!!!!!!! Is AOK... You did not offend me. LOL
silicone removal sibyrnes Cleaning, Stripping & Polishing 3 06-01-2005 08:52 AM
silicone inside Ghost Rider General Interior Topics 1 03-21-2004 10:48 PM
Blobs of silicone on screws? Kistler Our Community 9 06-24-2003 09:06 AM
Vulkum ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 03-20-2003 11:24 AM
Vulkum ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 04-22-2002 06:46 PM
