Old 09-01-2002, 11:40 AM   #15
gwsullivan's Avatar
towner7 (Vern), your advice did not go unnoticed. I have been 'off the net' for a few days. Thanks to all who answered. I will attempt to contact the factory next week and order some sikaflex.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 09-01-2002, 03:38 PM   #16
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks for the info y'all. I used Vulkum and also Dupont Aluminum sealant from Home Depot, and both went well and look good.
The aluminum sealant shines and blends well. The idea above for saving the vulkum in the freezer is a good one...thanks, and also I used mineral spirits to wipe down the vulkum as I put it on, but the dishwash liquid idea would be a great one to try next time- much less worrisome I bet.
Old 09-12-2002, 02:26 PM   #17
Removing Silicon
I need to remove my fantastic fan annd intend to replace the current silicon with vulken. Any suggestions for removing the old silicon? What breaks it down?
Thanks!
Charles Willson
Santa Cruz, CA
64 Globetrotter
56 Caravanner
Trotter is offline   Reply With Quote
Old 09-12-2002, 02:33 PM   #18
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
breakdown
I've used alcohol with the greatest of ease...Plus an old toothbrush to help "get at it"..The main thing is to get all of the old silicone up as Vuklum will not stick well to it..
I'd recommend keepin lots of clean rags handy..
ciao
53flyingcloud is online now   Reply With Quote
Old 09-25-2002, 05:33 PM   #19
Sikaflex
Sikaflex is commonly used in the marine world, so if you have a marine store or boatyard handy you might look there.
otha1 is offline   Reply With Quote
Old 11-10-2002, 04:31 PM   #20
Dabler's Avatar
Images: 22
Rivet
For what it's worth, I spotted the following on another website.
AIRSTREAM INC.
We use and sell Vulkem 616/631 sealant, only. We have it available in both gray and black. We do not recommend any other sealant for the exterior shell other than Parr Bond, or Sikoflex.
SOURCE: Airstream Service and Parts Department
And here's a link for more information:
http://www.airstreamdreams.com/generic.html?pid=29
Duane Abler
Dabler is offline   Reply With Quote
Old 03-15-2004, 06:00 PM   #21
silverlassie's Avatar
Vulkem
One of those "How do you do it" questions. How do you all keep a tube of vulkem "fresh", when you have just used a little bit of it?How do you seal it? I really appreciate all the help you guys are always so willing to give. Thanks!
Silverlassie
silverlassie is offline   Reply With Quote
Old 03-15-2004, 06:03 PM   #22
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I wrap it in saran tightly after plugging the tip and toss it in the back of the refer. It will keep for months. Just remember to let it warm up before you try to use it
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 03-15-2004, 06:25 PM   #23
The instructions I received with my fantastic fan said to use silicone - which I did. Then I read on this forum that silicone should not be used on aluminum.
At the Florida Airstream Rally I talked with a representative of fantastic fan about the differences of opinion and asked what they use when installing the vents in airstreams. I was told that they use a different product (I can't remember the name but one of the words in in was "leveling") They offered to sell me a tube but also assured me that while the silicone may not last as long as what they use that it would last for a long time, and they would not recommend reinstalling the vent. The good thing about silicone is that you can scrape it off. I haven't found anything yet that will remove vulkem.
Wayne
wayner1239 is offline   Reply With Quote
Old 03-15-2004, 06:40 PM   #24
On the contrary, fully cured silicone is virtually impossible to remove from aluminum. It has the curious property of adhering tenaciously, and yet not sealing out water. Even when you think you have it all off, there is often the thinnest of films left behind.
The caulk referred to as "self leveling" was likely Flow Seal, by Dyco. Boy does it flow. I had it flow through the mandrel of standard (not Olympic) rivets, and out the bottom!
Vulkem can be removed, but it is tedius. You remove all you can mechanically (scraper, beveled edge craft sticks, whatever), and then use mineral spirits to soften and remove the rest.
Mark
Old 03-15-2004, 06:55 PM   #25
I heat a brass scraper with an alcohol lamp and the hot scraper removes vulkem like soft butter. Mineral spirits clean up.
Dick
Navigator is offline   Reply With Quote
Old 03-15-2004, 09:17 PM   #26
jaco's Avatar
AIRSTREAM INC.
Duane Abler
NOTICE
It may be well to note that either the above info is incorrect or that Airstream Inc has changed their advice since Duane posted in 2002. The Vulkem that is recommended and sold by the Airstream Factory Store is now Vulkem 636. It is actually now labeled as Trempro Vulkem 636 made by Tremco.
I have used Vulkem 116 (it is the most readily available and the least expensive 2.95 per tube in Houston) It is thick and coarse and grainy. This is to replicate the texture and look of mortar. The product is used alot by the masonry repair industry. Good as a wide gap filler especially on roof around vents etc.
jaco is offline   Reply With Quote
Old 03-16-2004, 05:27 AM   #27
qqq
qqq's Avatar
Thumbs up
Jaco,
I love your sig, so true as far as i'm concerned, I'm going to get rid of it asap.
Hart
qqq is offline   Reply With Quote
silicone removal sibyrnes Cleaning, Stripping & Polishing 3 06-01-2005 07:52 AM
silicone inside Ghost Rider General Interior Topics 1 03-21-2004 09:48 PM
Blobs of silicone on screws? Kistler Our Community 9 06-24-2003 08:06 AM
Vulkum ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 03-20-2003 10:24 AM
Vulkum ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 04-22-2002 05:46 PM
