Old 03-20-2003, 11:14 AM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Vulkum
Is there any reason to remove and replace old Vulkum, such as around the TV antenna if there are no leaks right now, just wondering if preventive maintenance would include redoing it. I have already redone my windows and some smaller sealed areas.
Would you redo it with the same or use another sealant?
Old 03-20-2003, 11:24 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Not to be a smart a**, but the old adage a once of prevetion is worth a pound of cure. If it is looking bad, sure, why not. Not sure what other sealers to use, but if it doesn't look bad, there is another adage if it anit broke don't fix it!
Eric
« rain leak | Top | Parr Bond »
Rivet Replacement Mr Boo Ribs, Skins & Rivets 8 07-21-2014 12:58 PM
Polishing Again davidz71 Cleaning, Stripping & Polishing 16 11-17-2005 06:40 PM
Vulkum or Silicone?? gwsullivan Leaks - Weatherstrips, Gaskets, Caulks & Sealants 26 03-16-2004 06:27 AM
Vulkum ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 04-22-2002 06:46 PM
