Old 03-29-2010, 12:40 PM   #1
1978 28' Ambassador
Savannah , Georgia
Vulkem help
Can't say I am in love with vulkem. Here are my first two attempts. The antenna support and antenna base. Am under a pecan tree that is leafing and can't help the debris.
Am I putting this on too thin or too thick? Have chalked for years and this stuff is like nothing I have used before. Tried to get a thick bead and it globs. Smoothed it out with mineral spirits on tip of finger. Did not expect it to come out of the tube so "thin". Might have cut the tip too much.
Any suggestions appreciated.
Thanks. Jack
ID:	99030   Click image for larger version
Skamper1 is offline   Reply With Quote
Old 03-29-2010, 04:51 PM   #2
Thanks. Jack
Vulkem can be a little thin when very warm.
Generally speaking, don't make the bead any larger than necessary.
Old 03-29-2010, 04:59 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I like to use painters tape to make the task of vulkem application and cleanup easier. Just frame the area with tape and squeeze away. Don't pull the tape right away. Let the vulkem set up first.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-29-2010, 05:08 PM   #4
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Looks like too much too me. A 1/8" inch bead around the edge of the antenna plate is sufficient, then a dab on top of each rivet (no way to make the "dabs" pretty, in my experience). Up here in dry Colorado, I've had to wait days for the vulkem to cure.
And I've never had any luck smoothing it with a finger wet in mineral spirits. I just use the round corner of a plastic motel key, then a few hours latter (let it set up a little) clean up the thin stuff that the key spreads out.
You can get an almost invisible seam at the joints. Using the painters tape helps prevent the motel key from spreading the goo (well, it spreads, but you can just pick it up with the tape).
Zep
Old 03-29-2010, 05:09 PM   #5
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
..I second the masking...black electrical tape also works great if you're doing glass etc...
fotochop is offline   Reply With Quote
Old 03-29-2010, 05:15 PM   #6
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
I use Walbernize and terry cloth to clean off small smears that escape the caulking zone. Works cleanly and nicely.
I haven't found anything good to get the stuff out of my clothes. don't know how, but gets from my sneakers to my shorts and then the ladder and it ends up on all the wrong places.
Now paying attention to the old maxim, "don't caulk yourself into a corner".
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Vulkem? RandyG Exterior Restoration Forum 8 09-08-2009 01:45 PM
Anyone need some Vulkem bmklawt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 02-27-2009 07:16 AM
Vulkem? Annemac 2006 Safari 3 05-17-2007 02:34 PM
How much VULKEM??? Buttercup Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-19-2005 12:44 PM
Vulkem rnabors Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-08-2003 07:40 AM
