Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 08-17-2006, 06:15 PM   #1
Dano57's Avatar
Profile:  1979 31' Excella 500
Edmond , Oklahoma
Question Vulkem 635 or 636?
OK, so I'm new to Airstreams and have a bunch of questions. I am getting ready to re-install the fresh water tank in a 79 Excella 500 which sits in a steal pan bolted to the bottom of the trailer between the axles. I assume I should use Vulkem to seal it when I bolt it back up but Vintage Trailer Supply sells two kinds 635 and 636 - what is the difference and which should I order.
Dan
Dano57 is offline   Reply With Quote
Old 08-17-2006, 06:47 PM   #2
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Originally Posted by Dano57
...Vintage Trailer Supply sells two kinds 635 and 636 - what is the difference and which should I order.
Dan
Use the faster setting one (tack-free in 90 minutes, per the Vintage Trailer Supply web page) unless you know you need more than 30-45 minutes of working time. I found that it really wasn't tack free for something a little over two hours, but I believe the cure uses water vapor in the air (humidity) and I live in a low-humidity environment (Colorado).
Anyway, I was a little concerned about the working time, but it wasn't a problem. As a matter of fact, I'd like it to be even faster. The other type, the slow stuff, is really really slow, like still a little tacky the next day. Working time isn't that long, of course, but if you're wanting to get back to polishing, the slow stuff will stop you for several days. BTW, once curred, you can polish over it (polish, not compound or sand) and it completely resists the polish.
Hint on application. I put down a small bead, then fair it in with my fingertip. Then I take the corner of a plastic hotel key/credit card and use it to scrape the bead--removing extra Vulkem and getting a nice and tight bead against the seam (you don't need to do this on your belly pan bead, of course). Then I use a rag and mineral spirits to remove the thin film that has been spread by the plastic scraper, being careful to not remove too much of the bead in the process.
MindsEyePhoto AirstreamDoctor PygmyKayaker
"It must be laid down as a primary position and basis of our system, that every citizen who enjoys the protection of a free government owes not only a proportion of his property, but even his personal service to the defense of it." - Washington
Old 08-17-2006, 10:04 PM   #3
Dano57's Avatar
Edmond , Oklahoma
Thanks Zep, I cll and order some tomorrow.
Dan
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 09:35 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 12:25 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
