Old 06-20-2007, 09:56 AM   #1
dikku@mac.com's Avatar
Vulkem 611 vs 636
Oops. I used vulkem 611 instead of 636 to seal the new water heater on my AS. Any major problems with the substitution? It's all I could find locally.
dik
dikku@mac.com is offline   Reply With Quote
Old 06-25-2007, 01:38 AM   #2
1973 31' Sovereign
Portland , Oregon
Images: 22
I believe that I read somewhere that the formula for 611 works fine for an Airstream. As I recall the difference is that the texture is a little more grainey looking. That is so that it works well with masonry and looks more like grout. I have used some on my unit and sofar all is well.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 06-26-2007, 10:33 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
If you got the grainier Vulcum then keep your eye on it. I tried some and within a year it started to deteriorate. I have used Trempro 635 from Vintage Trailer Supply which leaves a slick/shiney rubbery finish.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 10:35 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 08:15 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 01:25 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-04-2002 12:49 AM
