Old 08-10-2003, 09:02 AM   #15
Airstream Production line
Attached is the photo I promised that was taken September 10, 2002, in Airstreams production line.
It clearly shows the type Vulkem used by them.
Again, it is used in spite of the fact that it is more expensive, because it does the superior job that Airstream desires.
Old 08-10-2003, 09:09 AM   #16
montanaandy's Avatar
Vulkem
Does Inland RV carry the 616? If so, how much per tube and approximately how many would I need to seal a new Fantastic Vent install + a new shroud (from Inland) for the Armstrong AC unit?
Montanaandy
montanaandy is offline   Reply With Quote
Old 08-10-2003, 09:27 AM   #17
We carry the Vulkem 616.
You would have more than enough with one tube to seal the fantastic vent.
It is not necessary to use any sealer on the AC shroud, new or old.
I will PM the cost.
Vulkem wrap stellablu Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 09-07-2003 09:31 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 12:25 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
