Old 07-16-2009, 06:52 PM   #1
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
vulkem
What's the best way to remove old vulkem? My fingernails ain't long enough
bimpy is offline   Reply With Quote
Old 07-16-2009, 07:33 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Old Klingon
If that doesn't work try a phaser. Or a heat gun with a plastic putty knife.
Sorry, couldn't help myself.
Old 07-16-2009, 07:39 PM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I used this for our black tank vent gasket repair...
Name:	SOLAR PANELS; ROOF LEAK 021.jpg
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-16-2009, 08:00 PM   #4
Ottawa , ON
Oh sure, a phaser, you rich guys have everything! Rivet shaver too, I bet.
Old 07-16-2009, 08:15 PM   #5
Missouri Valley , Iowa
bimpy,
Farmer Dan is offline   Reply With Quote
Old 07-16-2009, 08:36 PM   #6
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
vulkem and mineral spirits
m.s. seems to work good for me-but first i judiciously use a gasket scraper on the thick stuff. after the vulkem is thin, the ms softens the vulkem and then you can use whatever to get it off. scotch brite works okay. scrapers of various descriptions, too. as a final, I have been sanding the clean aluminum-the rough surface will provide nice adhesion to the new vulkem-or if not spreading vulkem, then a good surface for clear coat-or polishing,
wmarsha is offline   Reply With Quote
Old 07-16-2009, 08:43 PM   #7
bimpy,
I just finished resealing my roof vents and skylights today. When I had done all the openings except one using oak strips about 1/8 in. thick and sharpened with a miter saw to a 45 degree or sharper bevel, I thought about a plastic or nylon-like strip I got fron a tile center when I was tiling my home floor. It was a piece for a transition or threshhold. It is 1 3/4" X 1/4". Put a bevel of 45 degrees, or sharper if possible, on a handy length of this material. If you want a narrower strip, rip it with a table saw. Using a heat gun borrowed from a friend's body shop, I got the white, weather-checked material off without too much hassle. Don't get things too hot. Some sealer remained after the first removal attempt. Mineral spirits softened the leftovers enough that another pass with the plastic scraper removed almost everything else. Resharpen often if the scraper dulls. I also used the scraper to remove the vulkem above the widows. The white paint on the roof remained intact unless I got too aggressive.
Vulkem? RandyG Exterior Restoration Forum 8 09-08-2009 01:45 PM
Anyone need some Vulkem bmklawt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 02-27-2009 07:16 AM
Vulkem? Annemac 2006 Safari 3 05-17-2007 02:34 PM
How much VULKEM??? Buttercup Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-19-2005 12:44 PM
Vulkem rnabors Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-08-2003 07:40 AM
