Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 08-25-2006, 04:37 AM   #15
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Originally Posted by cameront120
Is Sikaflex suitable for all sealant jobs one would encounter on an airstream? Or does one need the Vulkem, Parbond and others mentioned here for specific tasks?
Vulkem and Parbond were the factory sealants back in the 70's and 80's and are still available. The factory currently uses Sikaflex and Acryl-R. My only reccomendation would be to stick with the same one thru out. If you start with Vulkem and Parbond use them thru out.
Aaron
WBCCI #2449 AIR #2495
Old 08-25-2006, 05:32 AM   #16
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
as lew mentioned,
vulkem is for the large jobs, roof vents, sewer vents etc. parrbond is for finer work like the edges of seams and around lights etc.
you really need both types.
john
you call them ferrets, i call them weasels.
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 10:35 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 08:15 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 01:25 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-04-2002 12:49 AM
