Old 03-23-2012, 10:05 PM   #15
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Anyone have any tips for sealant removal? I've been spraying mineral spirits on the old nasty stuff(grey sealant of some kind) and letting it soak in for a while I go back and start scraping,once I get the loose sealant off I spray again and repeat. Lots of work!
There has to be an easier way!
desertair27 is offline   Reply With Quote
Old 03-24-2012, 01:57 AM   #16
1981 31' Excella II
New Market , Alabama
62 Overlander
Personally, I think the Trempro 635 working time is a little long. The stuff tends to get stuff in it before it dries as it is. Other than for installing panels where you need long working times why would you want something that stays tacky for days. Parbond working time is a little too short. So maybe your Trempro 626 is better in 1% of the applications that the average user is going to be using it for. For sealing smaller jobs why do you need something that won't tack up right away? Nothing you have said about the 626 is making me want to use it and nothing I have read ether.
Perry
Old 03-24-2012, 04:04 AM   #17
Baltimore , Maryland
I never told you to use it or anyone else. Use what ever you want. You can also call it anything you choose, I really do not care any longer.
Old 03-24-2012, 04:56 AM   #18
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I use a heat gun (sparingly) and wooden scrapers. Orange sticks (ask a woman if you don't know) sharpened Popsicle sticks and tongue depressors are my weapons of choice. If you have silicone it is a whole different game.
Aaron
WBCCI #XXXX AIR #2495
Old 03-24-2012, 06:16 AM   #19
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Sandi and Bob
For larger areas like the awning I think sikaflex 721 would be your best bet,I understand it is currently used by airstream and is easy (easier) to work with than trempro and will clean up with soap and water. And it is uv resistant
Kevin
kevinb is offline   Reply With Quote
Old 03-24-2012, 07:15 AM   #20
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Aaron
I just tried some silicone remover I got from VTS and it works surprisingly well.
I'll try some heat and the wooden scrapers.
Ghanks
Old 03-24-2012, 09:00 AM   #21
wheelerimage's Avatar
1965 20' Globetrotter
1955 22' Safari
Butte , Montana
Images: 8
This is why I love Airforums. I thought that Vulkem was Trempro 635. Now I know that Vulkem is Trempro 626. Thanks for the info!
wheelerimage is offline   Reply With Quote
What is this camper? Kittypuke Vintage Kin 59 01-12-2013 02:58 PM
FOD Rally for 2012 blmitch5 Friends of Dorothy 391 06-22-2012 06:20 AM
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
What years did AS use OSB? Flynavy Repairing/Replacing Floor &/or Frame 2 03-22-2012 10:50 AM
