Old 02-27-2014, 07:58 AM   #1
thinktankair's Avatar
1961 16' Bambi
grass valley , California
Vent pipe seal
I sealed the seams on my 1961 bambi with vulkum and I am down to one leak. How do I seal the exterior of the vent pipe? Water is hitting thr pipe and rolling down into the trailer. It had some putty on it so I used plumbers putty, but that isn't going to work. What is the standard for sealing the vent pipe? Thanks!
thinktankair is offline   Reply With Quote
Old 02-27-2014, 08:14 AM   #2
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Get a vent cover, available from many RV suppliers. Here's one from Vintage Trailer Supply Not sure if it's 100% for a 61, but it should take care of the problem. Is there evidence of one of these around the vent?
DryFly is offline   Reply With Quote
Old 02-27-2014, 08:46 AM   #3
You can also use the Vulkem on the vent pipe.
Plumbing Vent Problem Thalweg Waste Systems, Tanks & Totes 0 02-10-2014 02:27 PM
Toilet and Tank Vent pipe plcement chromis Sinks, Showers & Toilets 1 01-16-2012 06:10 PM
Removing vent pipe without cutting? bennyg Ribs, Skins & Rivets 0 07-05-2011 04:42 PM
Fitting a Nicro vent to the existing Hehr vent Globie64 Roof Vents, Skylights & Fans 8 03-17-2011 02:35 PM
