Old 03-23-2010, 06:06 AM   #1
1978 28' Ambassador
Savannah , Georgia
Vent gasket questions
Finally removed vent cover. Think InlandAndy may be correct about replacing gasket. Used hairdryer (heat gun being purchased today) to remove alot of the old vulkem. There were still patches of orange residue. Tried wire brush on dremel. Not happy with scratches. Tried brake cleaner and did not effect them. MEK with scrub pad removed almost all of it.
Questions:
1) Is the area now clean enough to install new gasket?
2) Do I put a bead of vulkem down first before I place screen over pipe and then slide gasket over screen and into the bead of vulkem?
3) Once gasket is in place do I use vulkem to seal gasket to vent pipe?
4) Do I put a bead of vulkem on roof before I replace the vent cover or replace vent cover and then seal around the base?
5) Do I put a dab of vulkem in each screw hole before replacing the screws?
Thanks. Jack
Name:	Old vent gasket.jpg
ID:	98648   Click image for larger version
Name:	Vent cleaned up.jpg
Skamper1 is offline   Reply With Quote
Old 03-23-2010, 06:25 AM   #2
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Just replaced that on mine a few years ago. I vulkumed everything when I put it back together. It's up there and out of sight and I didn't want it to leak again.
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Ventline Bath Vent Gasket Replacement 2dabeach Roof Vents, Skylights & Fans 9 07-15-2015 08:23 AM
louvered stainless steel vent or chrome vent toastie Roof Vents, Skylights & Fans 0 10-18-2009 04:01 PM
Fan vent gasket installation fotochop Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-26-2008 11:37 AM
Loosening Vent Handles and Aluminum Vent Replacement kincaidjesse Roof Vents, Skylights & Fans 4 04-16-2007 10:37 PM
Exhaust Vent Gasket Alden Miller Roof Vents, Skylights & Fans 2 08-22-2006 05:38 PM
