Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 05-15-2006, 01:26 PM   #1
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
Question Vent Cover Leak
Well it's been raining here for the last 4 days so I thought I'd do some work on the inside of the GT. Found all the jackets in one closet wet!
Seems water is sneeking in around the drain waste roof vent, running down the outside of the vent pipe, dripping on top of the closet and wetting the clothes.
The previous owner had gone and siliconed around the vent cover which will make getting it off a pain.
The question is, is this vent cover like to a DWV cover on a house where the outer lip is inserted into the vent pipe? Is there a gasket under the cover? If so, what's the material? Anyone done one of these?
Looks like it's pop rivited on so at least those won't be a problem, but any info you savvy Forum menbers can provide is greatly appreciated.
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 05-15-2006, 01:48 PM   #2
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
That is an AS specific part (at least it's the only place I've seen it). And you can buy them new ( I just bought three), from vintagetrailersupply.com. And the installation is: put down a layer of Vulcem or Protem or whatever, place a screen over the pipe and put this down and rivet it down. Andy at Inland says that failure of these over time is responsible for many many leaks.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 05-16-2006, 01:50 AM   #3
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
i thought I remember that side vented covers were available so water could not even get down the center opening. I seem to recall inland RV having them.That sure is a poorly sealed up vent though .
Scott
scottanlily is offline   Reply With Quote
Old 05-16-2006, 04:43 PM   #4
Tom Nugler
Tom Nugler's Avatar
Thanks for the replies. I didn't want to go into this project blind.
If the weather clears up this weekend, I hope I can get them off without breaking them.
Thanks, Tom.
WBCCI # 6411
Old 06-05-2006, 01:00 PM   #5
Tom Nugler
Tom Nugler's Avatar
Fixed the Vent
Got the cover off last weekend. The cover was sealed with a old tar type tape. Water had eroded the seal and ran right down the pipe.
Name:	Vent Uncovered.jpg
WBCCI # 6411
Old 06-05-2006, 01:07 PM   #6
Tom Nugler
Tom Nugler's Avatar
Cleaned everthing up and resealed the pipe with Permatex Ultra Blue. We use this stuff in the shop for sealing aluminum oil pans and cases.
Cleaned and painted the cover, and re-installed with pop rivits.
Had a downpour two days later and the closet is dry as a bone.
Tom.
Name:	Vent Sealed.jpg
ID:	22027   Click image for larger version
Name:	Vent Finished.jpg
WBCCI # 6411
Old 06-05-2006, 02:32 PM   #7
AYRSTRM2
AYRSTRM2's Avatar
Armada , Michigan
THAT, is a top notch looking job. Did you seal around the edge of the vent cover?
John
Old 06-05-2006, 04:36 PM   #8
Tom Nugler
Tom Nugler's Avatar
Just around the top edge by the body seam and a little dab around the rivit holes. I didn't want any water that got under the cover to get trapped.
Tom.
WBCCI # 6411
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 07:03 PM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 09:28 AM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 01:05 PM
Roof Vent Original? pepper48 Roof Vents, Skylights & Fans 6 11-09-2002 06:44 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 07:28 AM
