Old 04-29-2011, 08:02 AM   #1
treeair's Avatar
1971 23' Safari
Bozeman , Montana
Uh-oh, Leak
Just got the streamer out of storage yesterday. Uncovered all winter but free. Checked it a couple times but had not been inside in awhile. When I went to pull out the rear bed there was water on the plywood and only the bottom of the mattress was wet. Subfloor below, where battery compartment is, was wet but not carpet heading inboard. There was no must or mold so the leak must have just happened. We had a ton of snow this year w/ many thaw freeze cycles w/ a lots of wet snow recently. I definately have degraded caulk at windows and roof penetrations which I will go at when it warms and stops snowing(July) but am concerned how much water is in between skins. Looking for any diagnostic ideas in this area. Rear, curbside window looks initially to be the prime suspect. Thoughts? Thanks for any suggestions.
treeair is offline   Reply With Quote
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Water Leak bumper Airstream danyfr67 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 06-07-2011 07:43 PM
Fuel tank leak 1985 345 classic st.stephan Classic Motorhomes 3 04-03-2011 10:08 PM
Battery Compartment Leak Ag'71 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 03-22-2011 08:04 AM
Can not find Propane leak bmklawt LP Gas, Piping, Tanks & Regulators 15 01-02-2011 10:01 AM
