Old 09-28-2015, 07:06 PM   #1
OffTheCouch's Avatar
2008 27' Safari FB SE
Mountain View , California
TremPro 635 vs. Loctite PL S-40
Has anyone used Loctite PL S-40 instead of TremPro 635 for external leak prevention? The Loctite product seems to be something that can be picked up at a local HW store and TremPro is a little more effort to obtain.
Thanks, -Andy
OffTheCouch is offline   Reply With Quote
Old 09-28-2015, 08:32 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I read the tech sheets for Loctite PL S-40. I would use it if I did not have access to TremPro. But, I have never been in that situation. I've always been able to find TremPro within a few minutes of home.
Alan
Old 09-29-2015, 11:14 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I used some.. doesn't seem to have same 'grab' on the aluminum... yes, the aluminum was properly cleaned before application.. For a 'quick fix', it is ok..
Peace and Blessings..
Channing
WBCCI# 30676
TremPro 635 -vs- OCI QUAD -vs- OCI H2U grndslm Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 05-19-2015 07:33 PM
Alternatives to Trempro-635 perryg114 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 12-12-2014 01:31 PM
Trempro 635 TravisA Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 10-05-2014 05:38 PM
Epoxy - Loctite Products Don Landis Upholstery, Blinds, Walls & Interior Finishes 11 11-26-2009 06:18 AM
Vulkem 635 or 636? Dano57 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 08-17-2006 10:04 PM
