Old 03-13-2009, 02:28 PM   #15
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
HappyCampeur, it's not that I have to carry "that one tube"
The situation is in the bath that the ABS plastic counter, shower pan and etc... sit next to laminate or painted aluminum with an anodize aluminum trim over the joint.
What is good for ABS to ABS?
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 03-13-2009, 05:10 PM   #16
1994 30' Excella
Mississauga , Ontario
It is always noted on this forum that using silicone sealant is a no-no.
Most silicone sealants have acetic acid in them(probably a solvent). This will of course have adverse affects on the aluminum.
In the glazing industry there are lots of applications where glass is sealed in aluminum frames with silicone. In that instance they often use Spectrum 2 silicone which does not have acetic acid in it and is compatible with aluminum.
So it seems to me that would be the product to use if appearance is an issue.
Personally I think that a polyurethane sealant is stronger and probably more flexible.
Al
Old 03-16-2009, 05:44 AM   #17
1989 34' Limited
Mont St-Hilaire , Quebec
Al
Al, you're spot on!!!!
HappyCampeur is offline   Reply With Quote
Old 07-28-2009, 12:02 PM   #18
1976 24' Argosy 24
Milford , New Jersey
Found your invitation. What would you recommend to reseal the window glass on our wrap around windows on our Argosy? The original gasket where the glass meets the frame is shot.
Gkiesel is offline   Reply With Quote
Old 07-28-2009, 12:23 PM   #19
You can use Vulkem or Sikoflex sealer.
Vulkem is slow setting, allowing you to clean things up, slowly.
Sikoflex is fast setting. If you slip. you have but a few minutes to clean it up, maybe an hour, at best.
Anyone need some Vulkem bmklawt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 02-27-2009 07:16 AM
Vulkem '70verlander Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 08-25-2006 04:32 AM
Vulkem/Trempro Question kevino Airstream Trailer Forums 5 06-20-2006 09:34 AM
Vulkem rnabors Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-08-2003 07:40 AM
vulkem art Our Community 1 04-13-2003 07:16 AM
