Old 06-18-2010, 02:42 PM   #1
2006 19' Safari SE
Southern Pines , North Carolina
Time to replace roof caulking?
Yo experts, need some advice. We have an 07 Bambi. have traveled from NC to Alaska via Alaska hwy.... from NC to Arizona and from NC to Everglades City Fla. in the past couple years. The Bambi has done great. My Question when should I replace the caulking around the roof seals and when it's time should I let the dealer do it?
cooter is offline   Reply With Quote
Old 06-18-2010, 02:56 PM   #2
2010 27' FB Classic
N/A , Texas
You should get up on a ladder and look at the seals and caulk. If they are compromised( cracked or dried out) replace as needed.
I would only have a dealer do it if I was unable to climb a ladder.
Old 06-18-2010, 04:58 PM   #3
Unless you havw some water leaks, the exterior seals should be good on your 2006 for at least another 5 years, and maybe even more.
Sort of depends on the ambient temperature, the roads traveled and if the running gear was not properly balanced.
Replace roof A/C with a window unit? musketeer Furnaces, Heaters, Fireplaces & Air Conditioning 20 06-07-2016 11:14 AM
My first time on the roof-any advice? Brow324 Roof Vents, Skylights & Fans 11 06-03-2009 04:55 PM
Replace roof vent cr062065 Roof Vents, Skylights & Fans 6 06-29-2007 04:47 PM
Re-caulking An Aluminum Roof Question 56Nomad Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 02-22-2007 06:17 PM
Roof Caulking flyfisher Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 06-08-2006 12:27 PM
