Old 09-28-2004, 10:06 PM   #1
nevisstudio's Avatar
Images: 8
the headache of cleaning old caulking
hello all..
we are trying to repair the front opening on the roof...(14x25)
when we bought the trailer the person before us jimmy-rigged a cover for the hole....they took liquid nails and caulking and screwed down a plastic/metal sheet over the hole....i know, complete bone heads..
here is our situation-
we got the screws out and removed most of the caulking through hours/days of work.....gotta love it...not
here are our problems-
1. the holes the drilled are outside the replacement cover...i was thinking of covering the screw holes and still rivit into original holes..or..add a skirt around and rivit into his holes...any suggestions..
2. any secret tricks on removing the liquid nails/phantom sealant....dont even know how/where to start attacking this....
any help would be very appreciative...
thanks
rich
nevisstudio is offline   Reply With Quote
Old 09-28-2004, 10:44 PM   #2
JohnG's Avatar
If the holes are not to large and you are able to rivet them I would just do that since it is on top and hopefully out of view. Don't forget to use some Vulkem or Sikaflex to seal the rivet too.
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 09-29-2004, 05:42 AM   #3
AND MAC TOO
Jalina's Avatar
Images: 36
Try what they call aircraft stripper. Can get at any automotive store. Did really well with silicone. It even worked on the orginal chaulk. Good Luck.
Jalina
Jalina is offline   Reply With Quote
Old 09-29-2004, 07:13 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
don't tell the EPA!
rich,
I feel for you, my PO used about 4 cases of silver colored silicone to seal things up. This is the technique I am using at the moment... Scrape the silicone down as close to the metal as possible without gouging, then wipe down with Methyl Ethyl Ketone use a rough rag, that will soften the residue, then scrub lightly with a plastic scraper or pad, it may take several passes, then wipe down with mineral spirits and it is ready to recaulk. I am ordering some OS12 and see how it does. If the MEK doesn't work on the liquid nails try something else like acetone, I usually use the stripper as a last resort.
Aaron
WBCCI #XXXX AIR #2495
Old 09-29-2004, 09:16 AM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We found Gasket Remover by Permatex to remove sealants that the Aircraft Stripper couldn't, may want to give it a try.
Shari
Old 09-29-2004, 03:12 PM   #6
Images: 59
Rich,
Did the previous owner remove the 'curb' around the opening? It may be that the holes which are outside the margins of the new cover were the mounting holes for the curb.
carb cleaning George Mechanics Corner - Engines, Transmission & More... 7 09-01-2003 07:55 PM
Caulking underneath? Kistler Our Community 2 07-10-2003 07:25 AM
Caulking Kistler Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-19-2003 12:32 PM
caulking ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-10-2002 02:13 AM
Cleaning a 41 year old AlumiTank? Andy R Fresh Water Systems 1 05-21-2002 06:54 PM
