Old 10-25-2010, 11:37 AM   #1
San Luis Obispo , California
The first big rains.
My trailer, before i took up residence and ownership, was lucky enough to stay under cover most of the year.....which means now that it isnt and the rains have started, I get a new initiation into vintage AS ownership....leaks!
Two so far, one that drips from the top middle of the streetside vista window, and one on the front that seeps in and is collecting on the plywood...but only in one spot, not the entire length of the plywood.
I think ive found the infiltration points, and one of these dry days before the next rain Ill get around to sealing them...but if anyone has had leaks in the same places, I'd love to know where your inflitration point on the exterior was, just to compare.
joelreh is offline   Reply With Quote
Old 10-25-2010, 11:45 AM   #2
x
XXXX , XXXX
Vista views almost always leak between glass and frame. The front leak can be the airstream letters, clearance lights or if you have astone guard over the front window the hinge that is attached to the trailer is only pop riveted on. Over time with the wind catching the guard when raised pulls these rivets loose. On the front window itself the upper corners of the wing windows may leak between the glass and the frame and again if you have the stone guard the support arms are pop riveted on and will leak.
wasagachris is offline   Reply With Quote
Old 10-25-2010, 11:50 AM   #3
Check the window and entrance door gaskets for cracks and old age, especially the sewer vent pipe cover gaskets, that only last 2 to 3 years.
The Vista view and stack windows can easily be sealed with Vulkem sealer.
How big is too big? Newbie Ponderings... mattlyon Our Community 22 08-15-2010 08:32 PM
Kitchen hood vent leaks when it rains rogerdodger Roof Vents, Skylights & Fans 0 05-26-2010 10:35 AM
Kitchen hood vent leaks when it rains rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 05-20-2010 08:38 AM
Big storm = Big dent TennisMan 2007 Safari SE 10 07-17-2007 09:20 AM
1982 280 Leaks when it Rains k_rasmussen Classic Motorhomes 10 11-24-2006 07:04 PM
