Old 12-21-2015, 10:15 AM   #1
2009 25' FB International
York , South Carolina
Tested various sealants - FYI
After reading lots of posts about the various products, decided to purchase a selection and test for myself. Project is replacing a couple of clearance lights on my 09 25 FB International.
Here's what I bought:
Sikaflex-221, Parbond, Trempro 635, ACRYL-R in 12 oz can with applicator, Aluminum Pigmented Gutterseal by Ply Gem Industries. Goal was to look at appearance, adhesion, dry time and overall toughness. I applied samples to a piece of aluminum on Dec 17. It is now Dec 21. Material is in a climate controlled area with average temp of 65 F.
Results:
Sikaflex-221 - Nice gray look, pulled cleanly away from aluminum without much effort (not sure if this is good), 24 hours was well cured, toughest product.
Trempro 635 - Nice gray and slightly shinier than Sikaflex, more difficult to pull away from aluminum and left residue, 24 well cured, slightly less tough than Sikaflex.
Parbond - Better aluminum look and easier to apply a tiny bead, clean removal from aluminum, 24 hrs well cured, tough.
Aluminum Gutter Seal - Nice aluminum color, makes a nice bead out of tube but self leveled out a bit more than I wanted, adheres well to aluminum, 24 hour cure, not as tough as Parbond.
ACRYL-R - Nice aluminum color, I didn't try applicator nozzle but placed a blob on aluminum. It self leveled to a degree. Very much adheres to aluminum and will be extremely difficult to remove. After 4 days material still may not be totally cured. At this point I can still move the blob around a bit with my fingernail.
Conclusions for me:
Either Sikaflex or Tempro for through the body sealing (wiring, screw holes, etc.). Parbond for appearance around light fixtures possibly.
Any feedback will always be appreciated
ID:	254254   Click image for larger version
bbodenstein is offline   Reply With Quote
Old 12-21-2015, 11:05 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I've used Parbond around lights. Works well for than, maybe due to it being dispensed from a tube.
Surprised the Sikaflex 221 pulls away easily. I was planning on using that on my roof vents this spring. I guess as long as it seals well, stands up to the elements and lasts a long time, easy removal is a good thing.
Kelvin
Old 12-21-2015, 11:29 AM   #3
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
I used Acryl-R to seal all seams on our 29' Ambassador. It does take a while to skin over but I think this will help keep the seal in place. I also like the way a bead shrinks in width as it drys.
Dennis
dennis3751 is offline   Reply With Quote
Old 12-21-2015, 12:28 PM   #4
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Acryl-R is my favorite for small seams - seems to stay flexible for years - workable if your quick.
Sikaflex - This product seems more workable than Trempro. Both seem to last about the same.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is online now   Reply With Quote
Old 12-21-2015, 06:15 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I like the Acryl-R for seam sealing. The "self leveling" helps the applied material wick into seams.
Jackson Center service techs were using Acryl-R when I was there for some major repairs. So I bought a can of it at their store in the waiting area.
David
Name:	1512 Window Acryl-R Bead.jpg
Old 12-21-2015, 06:40 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Did you clean the aluminum first? I also believe there may be a primer for Sikaflex. I would have to check on that one. The Sikaflex and the Trempro are very similar in chemical makeup.
Aaron
WBCCI #XXXX AIR #2495
Old 12-21-2015, 07:46 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
If you cleaned the aluminum surface prior to application (which is a MUST) and used any type of cleaning agent that contains any type of alcohol, then you have compromised the bonding properties of the SikaFlex.
I've been using it non-stop for 15 years and have NEVER been able to pull it from any aluminum surface when properly prepped. It doesn't even scrape well when cured.
Old 12-21-2015, 08:21 PM   #8
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Sikaflex-221, Parbond, Trempro 635, ACRYL-R in 12 oz can with applicator, Aluminum Pigmented Gutterseal by Ply Gem Industries. Goal was to look at appearance, adhesion, dry time and overall toughness. I applied samples to a piece of aluminum on Dec 17. It is now Dec 21. Material is in a climate controlled area with average temp of 65 F. ......
Did you make your tests on aluminum or clear coated aluminum?
You will get completely different results on Clear coats, I.e. Vulkem 116 sticks like thunder to raw aluminum , but can be peeled of after drying from clear coated surfaces.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-22-2015, 05:14 PM   #9
1973 31' Excella 500
Calgary , Alberta
What do you use to clean the aluminum.
DaKs is offline   Reply With Quote
Old 12-22-2015, 05:46 PM   #10
lewster's Avatar
Carburetor cleaner or mineral spirits. I prefer the carb cleaner.
Old 12-23-2015, 12:02 PM   #11
Many responses appreciated.
Thanks a bunch everyone. This is what I was after in originally post. I've learned a lot already.
Old 12-23-2015, 04:47 PM   #12
NC Camper's Avatar
2018 27' Globetrotter
Greensboro , North Carolina
Results:
Conclusions for me:
Very helpful info, thanks!
Is there any difference between the ACRYL-R that you used and the ACRYL-R sealant caulk in a tube? (Amazon.com: RV Motorhome Joint Sealant Acryl-R Caulk, 10.3 oz, Aluminum: Home Improvement) I don't know whether I could get a consistent application with a brush.
NC Camper is offline   Reply With Quote
Old 12-24-2015, 09:38 PM   #13
1990 32' Excella
jonesboro , Arkansas
Sealant
Try vulkem polyurethane caulk and see lf you like it .You don't want a sealant that pulls away from the surface with out major effort. Would not work in areas where it needs to flow in.
joel is offline   Reply With Quote
Old 02-02-2016, 06:51 PM   #14
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
how about brake cleaner the Non-Chlorinated type. Is this the same as carb cleaner. when using mineral spirits you just wipe down the area you are working on an let dry pretty much??
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Anyone road tested Towmaster tires Kistler Tires 38 03-04-2014 09:06 AM
The good old Barter system .. time tested! Airslide Cabinets, Counter Tops & Furnishings 57 11-29-2010 10:31 AM
Leak tested under pressure! deauxrite Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 11-23-2009 06:14 AM
Tested the Magic Chef/Thanksgiving Dishes Lothlorian Stoves, Ovens & Microwaves 4 11-27-2008 02:34 PM
Intellipower in and tested… Buttercup Electrical - Systems, Generators, Batteries & Solar 16 06-27-2005 03:35 PM
