Old 12-30-2008, 07:16 AM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Temporary leak fix
The PO took out the water heater and there is a piece of plywood over the hole, I am in the processes of changing out the furnace and the window above both may leak.
I don't believe any of these can be permanently fixed until spring, its 20 deg and there is to much rain and snow.
Anyone have any ideas?
Is there a waterproof tape out there that will stick to the aluminum through the winter and yet peel off without damaging the clear coat in 4 months. I was thinking of taping some plastic over the offending area untill it gets warmer out. I can get the shell warm enough to apply tape in this area, its the best idea I can come up with so far.
Your help will be much appreciated.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 12-30-2008, 07:47 AM   #2
Community Organizer
Guido's Avatar
2005 22' Safari
South Chicago , Illinois
Use two 2 by 4 boards, and some closed foam gasket. Glue the gasket on the plywood, put the boards on the inside of the trailer, and screw them to the plywood. It will clamp the plywood to the trailer, the gasket will seal the hole, and won't damage the clearcoat.
Fr. Guido
"We have just religion enough to make us hate, but not enough to make us love one another." Jonathan Swift
Guido is offline   Reply With Quote
Old 12-30-2008, 01:08 PM   #3
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Guido,
Simple and effective, Thanks
Bruce,
Old 12-30-2008, 01:20 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Or just apply butyl tape over any places where it may leak. I always carry some just in case.
Old 01-01-2009, 02:25 PM   #5
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Done
Guido and Wayne&Sam,
Thanks for the input.
I took of the plywood off and added a ribbon of foam around it and screwed it back on, I also applied butyl tape around it, the window and the water fill. Needed to use a heat gun to get the butyl to stick, it was 15 deg out.
Looks like crap but will hopefully keep the water out until spring when I can make a permanent repair.
I will also use the butyl tape around the furnace vent until it can be caulked this spring.
Name:	Leak fix 1.jpg
ID:	73232   Click image for larger version
Bruce,
Coleman AC Leak Fix Excellaphant 1987 - 1989 Excella 7 06-02-2011 12:36 AM
How to fix a leak coming through the a/c? JimGolden Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-16-2007 09:57 AM
Another Basecamp leak... and fix bobfowler Base Camp 3 08-12-2007 12:28 PM
How do I fix this leak? Becky B. Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 10-17-2006 09:25 PM
access to fix leak rvlover Plumbing - Systems & Fixtures 11 10-12-2005 02:49 PM
