Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 10-18-2009, 06:57 AM   #1
Profile:  1978 29' Ambassador
Indiana , Pennsylvania
Temperatures and Sealants
I understand the importance of having a clean and dry surface for use of parabond/vulkeme...but I need to seal some areas on our "78" ambassador and it is cold here in the Northeast. Does anyone know what the working temperatures should be when applying either of these? Thanks!
Roadrunner is offline   Reply With Quote
Old 10-18-2009, 08:05 AM   #2
Profile:  , Minnesota
Images: 59
I've had no problem with Vulkem down to 50F, and you can go even lower if you take a few precautions. Here's the cold weather application instructions.
As they say at the bottom, moisture cure sealants like Vulkem have been used down to -20F.
Temperatures of wheels Chipleyboy Wheels 1 01-25-2009 04:24 PM
Operating Temperatures guy99 Mechanics Corner - Engines, Transmission & More... 34 09-04-2004 03:25 PM
Sealants??? JAD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-15-2004 09:33 AM
Eternabond tape sealants Mariner Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 04-08-2004 07:54 PM
Refrigerator temperatures-time davidz71 Refrigerators 7 07-02-2002 02:56 PM
