Old 03-10-2008, 09:20 PM   #1
Excella CM's Avatar
1978 31' Excella 500
Venice , California
supersecretsource
What sources are there for the blue vinyl inserts that seal side to belly moulding strip?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 03-10-2008, 09:57 PM   #2
We have all the blue inserts for the belt line and rubrails.
Old 03-10-2008, 11:13 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Are other colors available? We are planning the paint scheme for our argosy and thinking about black (or possibly red) inserts for both belt line and rub rail, if we can get it.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 03-10-2008, 11:20 PM   #4
Janet.
Black is still available.
Red has been gone for years.
Old 03-11-2008, 04:05 AM   #5
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Do this strips fit most AS models as an add-on?
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 03-11-2008, 05:08 AM   #6
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Most Airstream dealers will order the vinyl insert for you. I have been able to get the two sizes I needed for my Sovereign in blue and the two sizes I needed for my Argosy in the orange. If you have the track on your trailer, it's very easy to install. Here's the emblem on the side of the Sovereign before and after. You can see the new vinyl insert on the top. I haven't put it in the bottom track yet. There is also a wide insert that wraps around the bottom of the trailer.
ID:	56004   Click image for larger version
juel is offline   Reply With Quote
Old 03-13-2008, 07:51 PM   #7
Don Boyd's Avatar
1971 27' Overlander
1970 25' Tradewind
1989 19' "B" Van Airstream 190
cromwell , Kentucky
another source
Try this site.
Search Results : ODMRV , Out-of-Doors Mart
and this,
good luck,
Don Boyd is offline   Reply With Quote
