Old 07-15-2007, 12:54 PM   #1
cameront120's Avatar
1972 25' Tradewind
Storing Vulkem or Sikaflex
Has anyone found a way to store a tube of either of these sealants, once the tube is open? I'm tackling a bunch of small jobs, as time permits, and don't really want to have to buy a new tube every time I need a few cc's of sealant for something. It seems that once open to the air, curing starts to take place. I've even tried wrapping the tip with celophane, but the curing process seems to carry on regardless. Makes me wish they packaged this stuff in small tubes, like the Parbond or Acryl-R.
North Vancouver, BC
Old 07-15-2007, 01:32 PM   #2
1983 34' Excella
columbia , New Jersey
I am a sikaflex distributor and I can tell you that we make sure the tip is full, then let it tack up before you put it in a sealed plastic bag and then into the freezer. We also store full tubes that way on occasion and that can extend the life for more than 1 year. Hopefully, this will help some. Bob Kren
rakren is offline   Reply With Quote
Old 07-15-2007, 03:14 PM   #3
1972 25' Tradewind
So it is possible! Thanks Bob!
North Vancouver, BC
Old 07-15-2007, 04:27 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I shove a fair sized screw in the end of the tube of Vulkem, wrap it cellophane and stuff it in the freezer. Haul it out to thaw the night before you need to use it. It does draw some interesting comments from visiting guests when they need to get some ice BTW it is also a sign of a Vintage Airstream owner in residence
Aaron
WBCCI #XXXX AIR #2495
Old 07-15-2007, 04:49 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
I didn't know you could cold-caulk a trailer!
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-15-2007, 05:04 PM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
AARGH -
That's a good one, CM.
Pat
pmclemore is offline   Reply With Quote
Old 07-15-2007, 05:23 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Thanks for the tip. I have tossed several tubes that have turned into core sample type material. I will have to print this thread out and show it to my wife. She thinks I have a few loose rivets now and when she sees what is sitting next to the Ben & Jerry's........
Richard
Old 08-30-2007, 05:24 PM   #8
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
I filled a syringe (from Vintage Trailer Supply) with Vulcem and then I've used it for small caulking duties. The ring-shank shaft from a bulb rivet fits perfectly in the dispensing end. Jam it deep and pull out with pliers to clear the orifice when you need more.
bevman is offline   Reply With Quote
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 09:35 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 12:25 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
