Old 12-06-2008, 10:54 AM   #1
64GlobeTrotter68Overlande
man7sell's Avatar
1964 19' Globetrotter
1969 27' Overlander
Snohomish , Washington
Standard or Non-Standard Roof Vent and Skylight
OK. So the skylight leaks and yes I've looks at most of the other posting. By hey, this can't be standard. Forward of my 'Galvanized' roof vent is a 12"x16" thin plexiglass skylight. Flat not domed and yes cracked and leaking. For one it overlaps the edge of the roof vent, no way that's going to seal well. Is this a PO mod?
Think I might replace the whole lot if I can find the right sized boat deck hatch.
ID:	72233   Click image for larger version
ID:	72235   Click image for larger version
man7sell is offline   Reply With Quote
Old 12-06-2008, 11:00 AM   #2
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I think this is a PO modification... if this is the very front vent... then yes, it's supposed to be one long vent about 14x26" if I remember correctly... see Vintagetrailersupply.com for a replacement vent... be advised, however, that 1) the vent cover does not allow light in 2) it's expensive 3) you need new "lifters" that are pricey (about $100 for both) 4) I don't see the tanges on the interior that should be there in your interior.
If I were you, I'd replace the whole lot with some new lexan and call it good.
Marc
Old 12-06-2008, 12:44 PM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I justed did a quick search and found several places that sell the plastic, the problem is that it appears that someone removed the entire collar/base of the original unit to install that 14x14 unit that is there. Might check with some of the airstream salvage yards like colaw RV salvage (1-877-548-2125), they have quite a few airstreams. I called afew weeks ago looking for parts for the 66 and the oldest they had was a 1970, but sure that a 70's one would fit close with minimal modification, might even come with the lifters already with it. InlandRV sells that replacement plastic lid for those, and it is solar gray (tinted of sorts) so light comes through it nicely.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 12-06-2008, 01:35 PM   #4
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
If ventilation is not important, I would agree with the above suggestion and fabricate a fixed polycarbonate (lexan) skylight.
If you want ventilation also, you will need to get or design some parts---the collar/base unit, lifters of some sort, and a frame for the lexan. Try the "search", advanced, and google search "hatch" and scroll down and bring up "Wally Byam hatch". That might give you some ideas if you haven't already done this. Your idea of a boat hatch sounds very interesting.
Not too far south of you is Singleton's RV salvage. www.singletonsrv.com/
They were closed for a while, but might be open now. They seem to have lots of parts.
I salvaged my lifters , original screen, and base/collar, built a frame with lexan and built my own vent/skylight. I still plan to frame out the inside of the vent with mahogany in my "spare time".
Sam
ID:	72239   Click image for larger version
samb is offline   Reply With Quote
Old 12-06-2008, 04:35 PM   #5
man7sell's Avatar
1969 27' Overlander
Not too far south of you is Singleton's RV salvage. Singleton's RV Salvage & Sales | We are here for you...check with us BEFORE you buy new!
Sam
Sam, that's a nice looking hatch.
Old 03-24-2011, 07:50 AM   #6
man7sell's Avatar
1969 27' Overlander
OK replaced the long skylight with a bubble long skylight, also got rid of my AC and put in an opening skylight with a fan (that is noisy and a power hog so that will go). Sealed them like I would on a boat with a bead of silicon and riveted. A little silicon on the top of each rivet. After the winter they are now both leaking. I'm guessing with the movement of the Airstream traveling that this is not the way to seal a skylight. Suggestions?
Old 03-27-2011, 08:41 PM   #7
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I have had the best success sealing my vents and skylights with butyl tape. I applied it to the cleaned aluminum surface and fastened the vent through the butyl tape to the body with SS screws. Rivets could also be used, I imagine. I then trimmed off the squeeze--out butyl and sealed the seam with Alcoa aluminum gutterseal from VTS. The gutterseal provides a secondary seal and helps prevent the butyl from drying out over the years. I have never had a seam like this leak and I am not one to avoid an off-road, rough surface adventure.
Sam
skylight leak
Heatpump vs. Standard AC Safari Tim Furnaces, Heaters, Fireplaces & Air Conditioning 56 04-25-2007 08:32 AM
Is this standard layout bertro Repairing/Replacing Floor &/or Frame 2 04-13-2007 08:03 PM
Any alternatives to standard plumbing vent? malconium Waste Systems, Tanks & Totes 12 03-17-2007 01:43 PM
Standard tanks sizes... Andrew22 Waste Systems, Tanks & Totes 13 10-25-2004 09:54 AM
Standard vs. option? silverback 1997 - 2004 Bambi 7 07-19-2003 02:00 PM
