Old 05-22-2014, 06:09 PM   #1
Anchorage , Alaska
Solvent to remove 1963 factory sprayed black tar
My 1963 Bambi has a sprayed "black tar" goo, used to seal the floor, "C" channel, and outer shell. I have done a shell off restoration, ready to reseat the shell, and want to reseal the shell/belly wrap/floor.
Can anybody suggest a solvent to remove the old black tar material, so I can get a good clean bond with a new sealant ?
Aktundra is offline   Reply With Quote
Old 06-19-2014, 04:30 PM   #2
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
I had great results with Citristrip for that tar-like substance. I used the spray on kind, let it set for about 20 min, and the majority of it was wiped off with a paper towel. Using some mineral spirits should get off any residue after that.
Airstreamin' dreamin'.
Follow our blog! http://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
??? How To: Remove Black Tar / Re-Seal ??? TxBxSx Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 04-08-2013 10:58 PM
tar removal? lisa.bivens General Repair Forum 17 07-10-2008 02:37 PM
removing leak "fix" of PO (tar) obxairstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 05-17-2008 04:33 PM
Sprayed vs. Baked on Clearcoat ricksre Clearcoat, Exterior Paint & Trim 18 04-10-2005 06:19 PM
Solvent welding dmadam Upholstery, Blinds, Walls & Interior Finishes 1 05-14-2004 01:04 PM
