Old 01-21-2012, 09:20 AM   #1
1981 31' Excella II
New Market , Alabama
Solvent for the white GOOP AS uses
Does anyone know of a good solvent for getting the white putty caulk off the inside seam areas? If they had used a more rubbery material it would have sealed better. There are lot of places the white stuff has failed because it has no tensile strength at all. I am doing some repair work around the door handle area and I am trying to get this stuff off.
Perry
Old 01-21-2012, 09:34 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Not sure of your specific caulk, but most can be removed with heat and the remainder with a solvent such as kerosene or other products of petroleum base. Keep ignition sources away from the work area.
Dave
Perry
Old 01-21-2012, 06:45 PM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
All of this has worked well for me.....
ID:	149326   Click image for larger version
Name:	SOLAR PANELS; ROOF LEAK 021.jpg
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-21-2012, 06:55 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I believe the white stuff on the older trailers is a butyl based sealant, if that is the case, mineral spirits are the solvent of choice. We use this in metal panel joints, as long as it isn't exposed to sunlight it will last a long, long time.
Aaron
WBCCI #XXXX AIR #2495
Old 01-22-2012, 06:24 AM   #5
1981 31' Excella II
It smells like oil. I think it is mineral based and not synthetic. It smells like what I remember traditional old school putty smells like. It has the consistancy of clay or putty even now. I have some mineral spirits I can try.
Perry
New Warm white Recessed Puck Lights Dan@LED4RV Commercial Listings 17 11-11-2015 09:10 PM
Wide White Wall Tires wasagachris Tires 14 08-04-2011 09:32 PM
Eastern Sierra and White Mountains Tour R2DTube On The Road... 9 08-04-2011 09:35 AM
White letter tires on Airstream Road Ruler Tires 2 03-09-2011 07:14 PM
