Old 04-09-2010, 06:32 PM   #1
1978 28' Ambassador
Savannah , Georgia
Solardome Vent Gasket
Replacing the gaskets/seal on all three vents. Thought I had ordered it already, but only have one piece. I was sent 1" wide by 3/4" thick foam. Tried to find more foam locally, but can only find 3/4" wide by 1/2" thick foam. Can I use the smaller size foam or should I just order the 1" wide? Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 04-19-2010, 06:06 AM   #2
1978 28' Ambassador
Savannah , Georgia
The 3/4" X 1/2" foam did not work as a replacement to the 1". Will order the 1" foam. At least I tried. Who knew a silly 1/4" would make that much difference! Jack
Ventline Bath Vent Gasket Replacement 2dabeach Roof Vents, Skylights & Fans 9 07-15-2015 08:23 AM
Vent gasket replacement ?'s Skamper1 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 03-29-2010 06:28 PM
Vent gasket questions Skamper1 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 03-23-2010 06:25 AM
Fan vent gasket installation fotochop Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-26-2008 11:37 AM
Exhaust Vent Gasket Alden Miller Roof Vents, Skylights & Fans 2 08-22-2006 05:38 PM
