Old 04-27-2012, 12:03 PM   #1
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Small leak question
Had our first real soaker down pour rain since we got our 72 Overlander, After it stopped I went out to admire my sealing job on the windows and roof vents,. To my shock I saw on the floor in front where the inside walls meets the floor are 2 small damp spots..
The only thing on the trailer I have not sealed is the outside blue trim around the bottom of the shell,, Is there any way water could soak in behind the trim and should that be sealed also?
I also saw that I forgot to seal around the trailer plug in where the TV wire goes.. But the leaks are more to each side and not in the center where the plug is..
So where do I start looking if its not the blue trim.. >>>>????
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 04-27-2012, 01:03 PM   #2
1981 31' Excella II
New Market , Alabama
Where in the front were they? There are tons of places to leak that you never thought about. The door frame area tends to leak because it sees so much banging. The Z stringer to the right and above the door had loose rivets on mine. The windows can leak between the aluminum frame and the glass. Water gets in there and can leak where the window frame seam is. Awning attach points are common places to leak as well as marker lights, and the scare light to the right of the door. Anything on the roof can leak and travel down the walls and end up in the floor. Battery boxes are another place to leak. You also want to check roof vents, sewer vents, TV antennas etc.
The bumper plate at the back is probably the worst and most expensive leak location. Tail lights tend to leak.
Leaks commonly show up in the 4 corners where the straight sections meet the curved sections. There is a gap in the C-channel there and any water that comes down the walls will end up in these locations. Some of us have bridged that gap and installed drains in the C-channel so water can get out.
Awning covers can have loose rivets because these see a lot of stress and many times pop rivets are used to attach awnings and they can leak.
Perry
Old 04-27-2012, 01:28 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the front of the trailer is down hill from the rear. The water could be getting in and running down the inner skin.
It will be tough to locate unless it is something like a vent etc.
Old 04-27-2012, 03:55 PM   #4
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
I sealed all the window glass,, window frames,, vents,, fans,, ac,, awning rail,, door light,, scare light,, clearance lights,, and on and on..
The blue trim at the bottom of the body is the only thing I have not sealed.. and the trailer plug in for the TV lights and brakes cable.. Got me...
When the sun pops out I will start at the top and work my way down again to see what I might have forgotten.. If I don't see anything I will do the garden hose soak from the bottom up till I find it,.. Since a leak can travel a long distance I will soak just one area and wait.. Then another,, and keep working up till I nail this leak..
Sodbust
Old 04-27-2012, 05:43 PM   #5
1981 31' Excella II
You can tape the suspect area as well and see if the leak stops. We had several long soaking rains over the winter and I found lots of leaks. The problem with leaks is sometimes it take a good long soaking for them to show up at all or there is a delayed reaction. The pink stuff has to get saturated before it runs down the walls and finds it's way out. A last resort is to pressurize the trailer with something like a leaf blower and spray soap/water mixture around any place that can leak. If you find the leak then you see bubbles.
It is possible to get a leak around the belly band. Sometimes the belly skins go under the top skin and sometimes not. If not, then you can get leaks.
Perry
Old 04-27-2012, 06:16 PM   #6
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Never gave it a moment to think that the insulation is sucking up water also.. Now that gives me an idea.. I can pull the control console panel out and reach between the skins and feel if the insulation is damp on each side.. if not that could rule out a roof or corner leak.. Will go try that right now..
Don't have a leaf blower,, will the 2 fantastic fans make enough pressure since I have all new window rubbers and door seal?
Thanks Sodbust
Old 04-27-2012, 06:23 PM   #7
Kenner , Louisiana
I gave up chasing leaks on my 73. Fix the big obvious ones and keep her out of the rain unless you are using the old girl. She has been around for over 38 years now, do not worry about a few tears from heaven. If she gets rained on while out camping, just park her in her cozy garage or covered patio and let her air out. My daddy always said if you want your toys to last you need to keep them out of the weather.
Good luck in your efforts however.
fourcatos is offline   Reply With Quote
Old 04-27-2012, 06:46 PM   #8
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Sounds like a job for Captain Tolley's Creeping Crack Seal. I've heard good things about it; found some today at Camping World to try out.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 04-27-2012, 07:23 PM   #9
Splitrock's Avatar
Sioux Falls , South Dakota
I had an occult leak after I had installed new window gaskets, sealed top seams, installed new roof vents, removed the television antenna, and resealed the vista windows. I ended up removing the inside skin from the door to the end cap and sat on a farmer's milking stool during a night thunderstorm with a poacher's light. The leak was a metered leak at the midway exterior skin lap joint where 4 panels meet.
From the outside it looked fine.
I sealed the inside and outside with Vulkem 116 and the leak quit. That was the last leak I had. That was 2010. I haven't had any leaks since.
Old 04-28-2012, 06:20 AM   #10
1981 31' Excella II
I had to pull the skins in the front to find all my leaks. I also replaced the cracked battery boxes.
Perry
Old 04-29-2012, 05:36 AM   #11
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Perry
Hope I don't have to go that far,, our inside is 97% unmolested.. Guess drilling a few rivets would not be the end of the world. Don't have any problem with the milk stool and sitting up all night watching for drips,, but will try a few ideas before pulling down skins inside. .
Sure got some good ideas that I had not found on my own. Now I need another hard rain....?
Sodbust
Old 04-29-2012, 09:54 AM   #12
Splitrock's Avatar
Yesterday I found the base flange of the front FanTastic fan I installed in 2010 is cracked and leaking. The tops of these trailers is a constant babysitting job. I see why people without scaffolding and ladders and access to a well equipped shop have Airstream leak anxiety disorder.
Old 05-19-2012, 05:18 PM   #13
Centennial , Colorado
I have a leak and floor rot in the floor under the sink/shower in my 1968 17' Airstream Caravel near the seam where the curved and straight edges meet. I will try to seal it with TremPro 635 and see if that fixes it. I just got my airstream and have never done any maintenance like this in my life. I hope I can seal it correctly. How big of a bead do you use? Thank you for your help. I really appreciate it.
drevell7 is offline   Reply With Quote
Old 05-19-2012, 05:20 PM   #14
Could a person use an air compresser to pressurize to find leaks? How do you do that? Just shut everything tight inside and put the compressor inside or ??
