Old 09-25-2004, 09:07 AM   #1
Silkaflex VS Vulkem??
Question:
A while Back I ordered some stuff from Andy, among which, I thought was 2 tubes of vulkem.
I got to looking at the stuff and one tube sez: Silkaflex 1A construction adheasive,
of which, I used most of caulking around windows/seams etc.
The other tube sez, Trempro/vulkem polyurethane sealant.
PLEASE tell me that they are simular!!!!!!!
I would hate to have to scrape the silkaflex out and start over
George is offline   Reply With Quote
Old 09-25-2004, 09:14 AM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Here's a whole thread dedicated to the differences between these and Parabond and the applications best suited for each.
Caulking and Sealants (vulkem&more)
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-25-2004, 12:09 PM   #3
Images: 59
Here is some technical information:
http://www.airforums.com/forum...8&postcount=19
Old 09-25-2004, 12:44 PM   #4
Thanks!!
It looks like it will work ok.
it is appreciated!!
Old 09-25-2004, 03:56 PM   #5
George.
Vulkem is a heavy fiberous sealer, that is used on larger seams. It also takes 24 to 36 hours before it starts to set.
Sikaflex is a heavy creamy sealer, that is also used on large seams. However it starts to set in about an hour.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-25-2004, 06:50 PM   #6
Thanks Andy,
I like the way the silkaflex applies/works/ sets up,
I haven't opened the tube of Vulkem yet, does it flow as well with simular charistics, other than taking longer to setup?
I tried Parbond and it seemed to shrink/crack when applied over old caulked window seaming.
I didn't like it, so I dug out all old vulkem/parbond and re caulked with silkaflex. I found that if I let the tube in the sun, it flowed much easier.
I am VERY pleased with the results.
Yess I found some "Sillycone" in a few places it was very easy to remove.
so much for it being newer and better. There are places for it, and it does make for a quick emergency, temporary repair.
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 09:35 AM
Vulkem Sale COArgosy78 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 06-29-2004 12:02 PM
vulkem art Our Community 1 04-13-2003 07:16 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 12:25 PM
