Old 09-19-2017, 09:29 PM   #1
2004 26' Land Yacht Gas 26
Thibodaux , Louisiana
Silkaflex 221 Gray Stains
I used Silkaflex 221 Gray on the top of the curved part of a 26ft land yacht, it leaves chalky gray lines down the side of the rig. Is this normal for this product. I did notice when I was applying it was very hard, not soft like most caulks.
latenite23 is offline   Reply With Quote
Old 09-20-2017, 07:31 AM   #2
dznf0g's Avatar
Oswego , Illinois
I've never experienced this.
-Rich-
Old 09-20-2017, 07:43 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
It may have bled a bit during the curing process. It should be stable once cured. You should be able to remove the streaks with rubbing alcohol. If the stains are too stubborn for the alcohol, try mineral spirits.
Bob Martel
WBCCI# 5766
Old 09-21-2017, 10:50 AM   #4
Pic
Here are some pics of what I am talking about, i was thinking of just peeling it and going with geo flex up there.
ID:	295290   Click image for larger version
Old 09-21-2017, 12:38 PM   #5
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
The stains should come off with mineral spirits or acetone
Matt
rugjenkins is offline   Reply With Quote
Stains on curtains and grease stains wallpaper near upper cookstove oxblood Upholstery, Blinds, Walls & Interior Finishes 0 04-07-2015 06:52 PM
Is there anyone who uses Trempro 636 & Sikaflex 221 on a 70's AS bennyg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-29-2011 08:16 PM
Sikaflex 221 gray? AirHog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-19-2011 12:22 PM
SikaFlex 221 buy locally? rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 10-18-2008 05:37 PM
Silkaflex VS Vulkem?? George Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2004 06:50 PM
