Old 03-10-2011, 09:46 AM   #1
1969 27' Overlander
Gold Hill , Or
Silicone tent seam sealant over rivet heads
Has anyone tried liquid tent seam sealer to seal around roof rivets? I know there is a lot of info/opinion/controversy about silicone sealants on our trailers but, a thin silicone sealer "painted" over the rivets of my roof might put an end to the persistent but fairly small leak I have. If I laid down a tape barrier along the path of the rivets then brushed a thin silicone wash over them, wouldn't it seep around and under the rivet heads and make a seal? Your thoughts will be most valuable, thanks!
jayg is offline   Reply With Quote
Old 03-10-2011, 10:04 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Silicone won`t stick to aluminum,unless it`s in a place you don`t want it. Dave
easyride is offline   Reply With Quote
Old 03-10-2011, 10:04 AM   #3
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Have you resealed all roof rivets and seams with Vulkum? The PO of our Safari had used silicone on the roof rivets but missed the leak which was around the vent pipe. It took us several days of very hard work to remove all the old silicone before polishing. I resealed all rivets and seams with Vulkum and got rid of all the leaks.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-10-2011, 10:07 AM   #4
DO NOT use any form of silicone sealer on the exterior of any Airstream ever built.
If you do, you will quickly learn all to many nasty words.
Use Vulkem or Par-bond.
Old 03-10-2011, 10:25 AM   #5
1969 27' Overlander
Gold Hill , Or
Andy, are suggesting that I use parbond to daub each rivet head or that I do the tape off thing then run a thin stripe of sealant down the lines of roof rivets?
leaks, seam sealant, silicone
Wall Rail Systems funkill Upholstery, Blinds, Walls & Interior Finishes 16 08-27-2012 04:50 PM
Airstreams and leaks Julie B Leaks - Weatherstrips, Gaskets, Caulks & Sealants 71 07-13-2012 04:38 PM
NEU 064 : NEU Chilly Man V Rally May 13-15, 2011 myboyburt WBCCI Rallies & Events 8 05-09-2011 12:21 PM
Need Advice on Seam sealing material nm1oqrz Ribs, Skins & Rivets 4 02-16-2011 11:44 AM
How much sealant do I need? WadenMichell Leaks - Weatherstrips, Gaskets, Caulks & Sealants 13 02-05-2011 08:55 PM
