Old 11-01-2011, 09:49 AM   #1
1964 19' Globetrotter
OH - Ohio , waynesville
Silicone removal...Help!
the PO of my 64 globetrotter went a little nuts with the clear silicone chaulk. I can scrape off alot, but there's still a fine layer left. Any ideas? Can I heat it? Also, when removing the fractured black water tank, which was dry, but certainly not empty, I discovered that it is encased in a very rusty holding pan. Since I do not plan to replace the holding tank, can I remove this pan without negative consequences. Replacing back section of flooring (for obvious reasons) and it appears to be only attached to the plywood and not to any of the frame.
as always, your advice is deeply appreciated
gottatrotter is offline   Reply With Quote
Old 11-01-2011, 10:24 AM   #2
65CV's Avatar
Western , Massachusetts
Caulk Remover
I had good luck with this to remove silicone caulk:
Pro De-Solv-it CONTRACTORS' SOLVENT™ REMOVES ALL THIS!
I'm pretty sure I got it at Lowe's or Home Depot.
Never had a metal holding pan. If it's at all like our '65, the holding tank did hold up the toilet, so I imagine that removing the tank will have more of an effect. You didn't mention what you plan to install instead.
John
65CV is offline   Reply With Quote
Old 11-01-2011, 10:31 AM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I found two things that worked fairly well on removing %#$@*! silicone:
McKanica Silicone Caulk Remover Gel and
Permatex Gasket Remover (although it looks like the formula may have changed because mine wasn't "Low VOC")
Neither worked as well I wanted them to - they both needed multiple coats, but they eventually did the trick. The Permatex will damage plastics & painted surfaces (even POR-15...don't ask me how I know!) so be sure parts are removed or protected.
Shari
Old 11-01-2011, 10:34 AM   #4
going with another bed in the rear. all bath fixtures were gone when I got her, and the floor and holding tanks were a disaster (taking on the flooring now). there are currently no sleeping accomodations left, just original cabinets, sink, stove. Planning to go very basic to begin with. Started with tires and brakes, they're done. Most of my budget will probably go to restoring the electrical system, (which is missing). I'll put in a fresh water tank, but no heater. Craft some type of couch/bed, and I'm on the road. I'm thinking years from now. It's become a much bigger job than I anticipated
Old 11-01-2011, 10:36 AM   #5
eek, this silicone thing is starting to sound like a problem. It's everywhere. Going to lowes..thanks john
Old 11-01-2011, 10:37 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I use cosmoline remover to soften the silicone, and a plastic razor blade to remove the silicone once it's softened.
Old 11-01-2011, 11:56 AM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
There *is* no known solvent for cured silicone; however there are a bunch of products that will attack the silicone bond to any other solid. That's the angle to fight it, soaking long term the joints it shares with metals & glass...
Old 11-10-2011, 09:49 AM   #8
1962 19' Globetrotter
Vancouver , British Columbia
ive just run into the same problem on my 62 and was searching for answers.
how can people be this dumb?
Any luck with yours?
Stupidnoob is offline   Reply With Quote
Old 11-10-2011, 10:06 AM   #9
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I have used the McKanica caulk remover with some good results but it takes quite a bit of time for the material to work. I think I used a stiff scrub brush and a plastic putty knife to remove and followed up with some car wash to remove the debris.
I believe 3m makes a remover but I haven't tried it.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-12-2011, 08:00 AM   #10
Airstream Fanatic
ND10CentCan's Avatar
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck , North Dakota
Oh my....
And to think my husband thought the PO of our Sovereign had stood about 6 feet away and shot silicone at the windows....he has got to see this one. It is hard to understand what goes through people's minds. Uffda.
Sandy
ND10CentCan is offline   Reply With Quote
Silicone caulk on aluminum edglenn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 43 12-21-2012 07:48 PM
silicone caulking for round stainless steel sink toastie Sinks, Showers & Toilets 6 04-07-2011 06:28 PM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
'75 TW fresh tank removal 1 man Breadbug Fresh Water Systems 4 02-01-2011 07:31 PM
