06-05-2009, 03:58 PM
Petersburg
, Virginia
Silicone ok for quick fix?
I had this at the end of another thread but I don't know how to move the post...sorry for posting the same question twice...
We've got leaks in most of the Vista View windows on our 1974 Sovereign. Planning to polish the exterior within the year and also replace the tint (removing windows as necessary). Would clear silicone caulk work ok for a quick fix? We just want to stop the leaking for now and do the windows properly when we get to them. Seems like clear silicone would plug the leaks but then be pretty easy to peel off when we're ready.
Thoughts?
06-05-2009, 04:03 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
NO NO NO,silicone is about useless on alum.,use Vulcum.or something like that,I`m having a brain lockup. Dave
06-05-2009, 04:19 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Becky,
Problem with silicone is that it will leave a residue that is almost impossible to remove and will keep any other type of sealant from sticking to it. Are the leaks at the frame and shell or frame and glass? If they are at the frame and shell I have used aluminum tape (available at your local home improvement/hardware center in the HVAC area) to seal a small to medium sized leak. Not very pretty but does the job and can be easily removed. Vulkem 636 or Sikaflex 721-UV are the caulks of choice. Airstream used to use Vulkem but switched to Sikaflex a while back.
Aaron
WBCCI #XXXX AIR #2495
06-05-2009, 05:00 PM
St. Cloud
Silicone works too well and not well enough all at the same time. Too well - you can't get it off later. Not well enough - for unpredictable reasons certain areas of a silicone seal on aluminum never adhere and you still have the leak. Think I've heard it blamed on the tendency of any exposed aluminum to develop an oxide layer immediately. Blame our blue marble...
I had a friend who had a Cadillac boat (yes, that Cadillac) and he recaulked it about 3 times before he recycled it. I didn't know and couldn't tell him at the time that the leaks he kept experiencing were the result of his caulk and not the ill-fated boat.
06-05-2009, 05:32 PM
1999 25' Safari
Fairburn
, Georgia
One of the problems with silicone (RTV) is that it contains acetic acid, which will corrode aluminum.
06-05-2009, 06:30 PM
1977 31' Excella 500
Berkeley Springs
, West Virginia
What about the GE stuff?
What about the stuff that GE makes that is supposedly formulated just to work with aluminum? They claim it's good for 50 years.
- Jim
06-05-2009, 06:41 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
I still won't use it. If it fails you have an unholy mess to clean off. FWIW Airstream at one time tried silicone and promptly went back to the Vulkem. IIRC it was around 1974.
Aaron
06-05-2009, 07:05 PM
1968 28' Ambassador
Cedaredge
I've used the aluminum stuff for gutters and it works well, and is the right color...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
06-06-2009, 10:53 AM
Berkeley Springs
, West Virginia
I've only used silicone in one place, and I got that tip from the Avion forums (oddly enough I currently have an Avion trailer ); that place was under the giant rubber/foam gasket for the new a/c.
I'd replaced the gasket on the old a/c and it would still leak in a driving storm. One of the old timers on the Avion forums said that when he got his a/c replaced in the 80's, the dealer squirted some type of stuff around the bottom of the gasket where it touched down on the aluminum skin. He asked about it, and the guy told him it was factory procedure to do that. Said they never leaked that way. Otherwise, they'd tend to leak as the gasket got older.
Well, I had had the same thing happen to me when I changed the gasket and didn't add the goop. So when I just installed my new Carrier AirV, I shot some of that GE aluminum silicone around the bottom of the rubber gasket and tightened her down. We've had some strong sideways rain strorms of late and not a drop came in. But I guess time will tell.
On the roof seams, I used aluminum Kool Seal. That's what the SilverAvion guru's recommend (Dr. Gradeless is the Inland Andy of Avions and Dr. G says to use nothing but aluminum Kool Seal on the roof seams...) and she's been dry as a bone.
But under the a/c gasket is the only place I've ever used silicone.
Best of luck,
- Jim
06-06-2009, 02:00 PM
1974 27' Overlander
Puyallup
I used silicon on my AS many, many years ago... It worked just fine (applied over clearcoat) and lasted for many years. Recently, in a effort to chase down leaks, I removed much of the silicon and re-applied Vulkem in its place. It is difficult to remove, but what you can't get off by peeling, you can get off with paint thinner
06-06-2009, 03:11 PM
1971 23' Safari
Groveport
, Ohio
I have used clear latex caulk for a temp. fix. over a window frame and removed this spring with no problem and replaced with vulcem. Robert
06-06-2009, 03:46 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I carry some butyl tape in case I spring a leak. Certainly it's temporary, but it works and comes off easily.
06-24-2009, 07:20 AM
1977 31' Sovereign
New York
, New York
where does one get vulkem of sikaflex?
06-24-2009, 07:43 AM
1973 31' Sovereign
Danielsville
, Georgia
Parbond is really nice for small seams and around window frames.
Parbond and vulkem can both be purchased from InlandRV (CA) or Vintage Trailer Supply (somewhere on East coast)
06-24-2009, 09:19 AM
Tucson
, AZ
Don't do it !!!
I've been scraping silicone off my Silver Olive for a couple months (little at a time - especially in the heat). It has definitely damaged the aluminum: fairly heavy corrosion/deterioration under the bead/length of silicon where applied. Now I have permanent grooves along many of the seams, above windows, above the awning and around the vents. Nice.
06-28-2009, 07:37 PM
Petersburg
, Virginia
yikes. ok, I definitely get the picture!
09-20-2009, 09:40 PM
1975 25' Tradewind
, Michigan
Dreaded Silicon Caulk - Boo Hoo
OK....now what and HOW??? Last fall, during winterizing, a camper center "caulked" around a vista view per our request. They used clear silicon and pretty much smeared it along the top of the window frame where it sets into the shell.
When re-caulking, I believe you should remove the old, dried/cracked caulk (even though a tour guide at JC said they would just caulk over it there!) If so, what tool (dental pick?) would you carefully use. The exsisting caulk is white in color with a sort of grainy, rather than smooth finish, is to all windows, door, rub rail, in a perfectly applied 1/4 " line.
Thanks a bunch, Sue
(oh, and volunteers are welcome for this project!!)
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
09-20-2009, 10:27 PM
1976 Argosy 24
Joplin
, Missouri
I buy Sikaflex from local RV dealers. Most don't carry Vulkem.
09-21-2009, 06:28 AM
1964 17' Bambi II
Schererville
, Indiana
Thanks a bunch, Sue
Harbor Freight has a nice little dental tool kit that comes in handy for removing the old caulk. Sounds like you have Vulkem/Tempro around your windows & doors. If you aren't experiencing any leaks, you don't really have to redo it, but the tools come in handy if you have to remove it. The silicone is a pistol to remove. My trailer was covered in it when purchased. I didn't have many fingernails left & used the dental tools to death. It's just a time consuming tedious job. No special tricks, just time!
Becky
1964 Bambi II
1988 Avion 32S
09-21-2009, 04:27 PM
1975 25' Tradewind
, Michigan
Originally Posted by beckybillrae
"..... If you aren't experiencing any leaks, you don't really have to redo it, but the tools come in handy if you have to remove it. The silicone is a pistol to remove. My trailer was covered in it when purchased. I didn't have many fingernails left & used the dental tools to death. It's just a time consuming tedious job. No special tricks, just time!
Thanks Becky. The rain water is coming out from the two side windows that are across from one another and dripping on the "ledge" - Vista View windows above. Of course, there's no easy way to determine where the water is getting in.
Does anyone know if there's a "safe for Airstream" solvent to remove the silicon? Grrrrrrrrrrrr!!
Sue
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
