Old 10-04-2011, 07:03 AM   #1
1969 27' Overlander
Albuquerque , New Mexico
Silicone caulk on aluminum
I was concerned about an earlier thread that stated to NEVER use silicone caulk because it eats aluminum (which I have done ), so I called DAP Products directly to find out why.
Here's their answer:
The silicone based caulk etches aluminum because of the acetic acid content. It's the Acetic Acid that attacks the aluminum, not the silicone.
They recommended the following caulks, that have 30-50 year service life:
Butyl Flex
Dap 3.0 (Silicone hybrid w/o acetic acid)
Latex
I know that Vulkem (Sikoflex) and Parbond are the preferred sealants, but HD and Lowes don't carry them, and sometimes it rains TODAY, not next week.
Hope that helps!
edglenn is offline   Reply With Quote
Old 10-04-2011, 07:41 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Just a quick clarification: SikaFlex is not the same product as Vulkem. Also, Tempro (which bought Vulkem as I understand) makes several grades of these essentially one part polyurethane sealants
You can easily get them on-line and store them in your freezer, where they will stay fresh way beyond the expiration date. Also, some well-stocked RV stores carry them, as do many Fastenal stores.
Old 10-04-2011, 07:58 AM   #3
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Butyl Flex
Latex
Hope that helps!
Your post had me going for a bit.
Because of a leak near the stove exhaust vent cover, I used GE's Premium Waterproof Silicone II.
Just finished a call to their hot line and was assured that their Silicone II contained NO acetic acid. They went on to say that their plain silicone brand DID contain acetic acid and was not suitable for aluminum.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 10-04-2011, 09:53 AM   #4
cameront120's Avatar
1972 25' Tradewind
Sikaflex and Vulkem are not restricted to RV's in their applications, either. They are used extensively by the window and curtain wall industry. So if you have supplier of glazing supplies near you, that would be another source. Failing that, as others have said, order it online.
North Vancouver, BC
Old 10-04-2011, 10:51 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Do yourself a big favor
Fastenal in Albuquerque, NM | Albuquerque Fastenal - YP.com
Old 10-04-2011, 11:06 AM   #6
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
wouldn't 'etched' at the contact point mean the sealant gets a better bond?
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 05-24-2012, 10:24 AM   #7
sunny 75
sunny75's Avatar
1975 27' Overlander
selah , Washington
I'm still in the process of removing what seems like gallons of silver/gray silicone caulk from seams, rivets and everywhere imaginable. Please do NOT put silicone on your airstream. It's airstream abuse!
sunny75 is offline   Reply With Quote
Old 05-24-2012, 12:07 PM   #8
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
For the umpteenth time, and to reiterate what MurreyWalker posted, I have used GE Silicone ll formulated for Aluminum and Metal (100% silicone; no acetic acid, high-fructose corn syrup, or phosphates) with the same amount of apparent success as the Vulkem, and with better success than Parbond. I have used it to seal, with a small, neat bead, around my window frame-to-skin areas, and around the tops and sides of the running lights. Looks today like 5 years ago, no leaks.
(Disclaimer: I have also used an RV cover to keep the bird s**t and pine sap off my trailer (with 100% success), have mixed greywater into my black tank without killing my family or destroying my trailer, and tow with a non-Hensley hitch. I also put in non-Henschen axles, have no flamingo ornaments, and belong to no club.)
"When silicone is illegal, only illegals will have silicone"
tphan is offline   Reply With Quote
Old 05-24-2012, 01:21 PM   #9
Kenner , Louisiana
I have to agree with sunny. I spent 2 days removing that trash. DO NOT USE SILICONE!!!!!!! Do the job right and have some respect for your trailer.
fourcatos is offline   Reply With Quote
Old 06-11-2012, 09:25 AM   #10
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Sounds like silicone really adheres, which is a plus in my book. I think you'll have the same "problem" with vulkem if you ever decide to remove that. My AS also had a lot of clear silicone smeared on with the PO's thumb, and was indeed ugly and hard to remove. I cleaned it all up, and hope now that the neat bead of silver-grey GE silicone II (specially formulated for aluminum) that I have around the windows is equally durable. It appears to be.
I have respect for using one's powers of observation and reasoning, and somewhat less for the acceptance of "group-think".
Old 06-11-2012, 11:00 AM   #11
Ahem, yasss ...kaff-kaff
egad's Avatar
1969 27' Overlander
Bloomington , Indiana
Speaking as a building contractor, I'm not a big fan of silicone. It adheres to some surfaces, but not others such as asphalt shingles. What it does stick to it sticks very well which can also be a problem when it comes time to repair/replace something. Butyl caulks are far superior IMO, because they seal very well but are relatively easy to remove with ordinary tools. I sealed Betty's fridge vent with this and it worked just fine.
egad is offline   Reply With Quote
Old 06-11-2012, 03:24 PM   #12
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Once silicone adheres it leaves a film. The film is very difficult to remove and will stop any other type of sealant from adhering properly.
Perhaps the new formulations of silicone are an improvement, I honestly don't know. What I do know is that Vulkem/Trempro or equivalent sealants from Sonneborn or Sikalastic are much easier to remove and reseal when the need arises.
Aaron
WBCCI #XXXX AIR #2495
Old 08-03-2012, 08:44 PM   #13
pickpick
1966 28' Ambassador
Jonesboro , Arkansas
I went by my local RV repair place and asked what to use to seal around my plumbing vent pipes on top. He handed me a tube of Manus -bond silicone rubber sealant. It doesn't say it contain acetic-acid. Is this okay to use on our 66 ambassador? Thanks.
lizpickering is offline   Reply With Quote
Old 08-09-2012, 09:22 PM   #14
Jenniflow's Avatar
1982 34' Limited
1986 34.5' Airstream 345
Sausalito , California
Send a message via Skype™ to Jenniflow
Question How DO you remove silicone?
OK, it sounds like there are some subtleties involved here, this is very helpful.
(See also the thread: http://www.airforums.com/forums/f456...aks-66628.html, which has a more thorough discussion of the varieties of silicone.)
But here's the thing. If you find that the PO has used lots of silicone, what IS the best way to remove it? Is there are good, safe solvent for it? Or is it just a matter of scraping with a plastic tool or something? 'Cuz I got some silicone and it ain't pretty!
Jenniflow is offline   Reply With Quote
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 05:47 AM
RemovAll 220 - will it remove old caulk? malconium Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-21-2011 08:26 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 10:38 PM
