Old 09-25-2012, 01:46 PM   #29
aftermath's Avatar
Spokane , Washington
Aage, I was going by others have said about the silicone formulated for use with aluminum, the kind without the acetic acid. Again, if this product is out there then the argument against it eating the aluminum is void.
I have not used any of this on my trailer so I can't speak with any authority.
aftermath is offline   Reply With Quote
Old 09-25-2012, 02:31 PM   #30
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Silicone Caulk Attracts Dust
Cured silicone caulk attracts dust.
Almost all caulks must be protected from dust, blowing sand, kitty hair, etc. before they dry.
But silicone attracts dirt after it dries.
The wider the bead, the uglier the dusty strip.
I'm not sure why dust adheres to silicone more than urethane based caulks, but it does.
On a related note, I spent big $$ on replacement windows for my home in Albuquerque. The installer fastened the trim around every window with silicone adhesive. After a couple years of dust collection, the window trim looked terrible. It cost me more big $$ and much stucco damage to have the silicone removed. After a whole house re-stucco, a real expert on coatings and sealants sealed the joints where window frames meet stucco with architectural quality, varathane caulk.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 09-25-2012, 07:24 PM   #31
cameront120's Avatar
1972 25' Tradewind
I'm assuming you mean urethane?
North Vancouver, BC
Old 09-25-2012, 07:37 PM   #32
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Urethane it is
Varathane is a name brand description of generic urethane. My mistake.
Ken L
1966 Tradewind 24
Old 09-25-2012, 09:04 PM   #33
1972 25' Tradewind
When I see Varathane, I think wood finish.
North Vancouver, BC
Old 12-18-2012, 07:22 AM   #34
Phoenix , Arizona
Like with the trailer hitch threads, the caulking threads have me totally confused. http://www.airforums.com/forums/f456...ure-87316.html
I'd like to use what works best and do it once (at least for the forseeable future.) I'm thinking I may have some silicone to remove at the rear. I have matching dents on both sides of the rear with a leak on the right. I was hoping just to stop the leak and not get into a remove and reinstall process but I'm willing to do it right once if I can figure it all out.
If I were to purchase McKanica Silicone Caulk Remover Gel (as recommeded above) how much do I need (how far does one tube go?) Have others used this with good results or is there a better product???
Thanks!
Cheryl
girlscan2 is offline   Reply With Quote
Old 12-19-2012, 06:19 AM   #35
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
This should give you an idea how far a supply will go.
Thanks!
Old 12-19-2012, 07:57 AM   #36
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I've used McKanica Silicone Caulk Remover Gel with good results. I purchased the 8 oz. cartridge and glad I did as I needed to go over a few spots a couple of times. IMO the key to success is to spread it over the silicone w/finger (use glove) and give it time to work a day or more. I had some left over so I taped up the end of the tube and put it in the freezer with my left over Tempro.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 12-19-2012, 10:27 AM   #37
sunny 75
sunny75's Avatar
1975 27' Overlander
selah , Washington
removing silicone
I spent days removing silicone this spring and never found the magic remover. The most effective strategy I found was to use the Aircraft Remover (a Rustoleum product) that I also used to strip the clearcoat. The spray is especially lethal with sunshine heating up the aluminum. It literally sizzles! Repeated applications and the rubber scraper and a lot of elbow grease eventually did a pretty good job of getting most of it off. Be persisitant. I'm happy with the results and with the caulk residue left in the seams, we have no leaks!
sunny75 is offline   Reply With Quote
Old 12-20-2012, 07:27 AM   #38
Phoenix , Arizona
Thanks Ganglin, Tim and Sunny! More projects for a sunny day (which we have plenty of here.)
Cheryl
Old 12-20-2012, 01:00 PM   #39
Dwellstream's Avatar
2012 27' FB International
Brownsboro , Alabama
I am in the glass & glazing business and most of the shops, at least in the southeast, stock and use Tremco Dymonic polyurethane. I checked what we have in stock today, and it is FC for fast cure.
We stock RTV (room temperature vulcanizing) silicone which has no acid. You might check with the local glass shop in a pinch. Most towns have one.
Dwellstream is offline   Reply With Quote
Old 12-20-2012, 07:14 PM   #40
Ottawa , ON
Odd how close that is to the name of the most popular sealant used on Airstream trailers: Trempro (formerly Vulkem). Trempro 635 is one variation; it comes in different colours.
Old 12-21-2012, 09:52 AM   #41
1972 25' Tradewind
Aage, Vulkem & TremPro are both products manufactured by Tremco.
North Vancouver, BC
Old 12-21-2012, 07:24 PM   #42
Ottawa , ON
That makes sense, cameron. Thanks.
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 05:47 AM
RemovAll 220 - will it remove old caulk? malconium Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-21-2011 08:26 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 10:38 PM
