Old 10-22-2010, 07:40 AM   #1
gary larocca's Avatar
1966 24' Tradewind
oldham,co. , Kentucky
Question Silicon sealant on install of corning window?
Good morning,
I was looking for info on what type sealant to use on installing corning glass in our 66 TW. I only have the one(front flat)to do and want to do it right.
Any info would be great.....Should I redo the others?
gary larocca is offline   Reply With Quote
Old 10-22-2010, 07:55 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The First Commandmant of the Gospel of Zen and the
Art of Airstream Maintainance:
Thou shalt not use silicone for it is an abomination before Wally, useth thou Vulkem and suffer not the wrath of those who profess to be among the righteous.
Old 10-22-2010, 08:24 AM   #3
There is indeed one use for silicone sealer on the exterior of an Airstream.
Installing the opening windows on a 66 Airstream, requires the use of a sealant within the hinge, to hold the glass in place.
That's how Airstream installed them.
In 67 and 68 the window hinge opens up allowing double sided tape to be used.
We agree, that Vulkem would be better, but it takes many hours to set up. Next, if that same window ever had to be replaced, removing the broken glass and the old Vulkem sealer, would be a task that would most likely generate more "nasty words".
Need to remove '68 Corning Window Trim inTransit Windows & Screens 1 08-11-2010 09:17 AM
wanted '66 corning window latches shezatrotter Windows & Screens 2 05-16-2009 09:41 PM
Corning Glass Window Trim Replacement rasmuw Windows & Screens 3 01-01-2008 01:44 PM
